Ambient Pressure Sensor for VW G3 AFN ECU
reuselkopp
Post27-11-2009, 10:47    Subject: Ambient Pressure Sensor for VW G3 AFN ECU Quote
Hello everyone,
Okay, it's happened to me too. I'm getting a non-erasable error code that says "control unit defective" intermittently. It seems to be the ambient pressure sensor. Has anyone found a source for this sensor where you can order it individually? Or perhaps someone has one lying around that they no longer need?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 23-10-2026, 5:29.
by KeeSoft
Avatar-by KeeSoft
2006 Audi A4 Avant
Post29-11-2009, 23:16    Subject: Ambient Pressure Sensor for VW G3 AFN ECU Quote
hello,
The ambient pressure sensor is integrated into the mass airflow sensor (MAF), and it can be accessed/found [depending on the intended meaning].
Part number 074 906 461 can be purchased for approximately €120.00 at icon_biggrin.gif.
Sincerely,
KeeSoft
Translated on 23-10-2026, 5:30.
Post29-11-2009, 23:24    Subject: Ambient Pressure Sensor for VW G3 AFN ECU Quote
by KeeSoft wrote:
The ambient pressure sensor is integrated into the mass airflow sensor (MAF), which can be accessed by...
No, it's not in the LMM (likely referring to a mass airflow sensor), and it never has been. The sensor is located in the engine control unit (ECU).
Translated on 23-10-2026, 5:31.
Wiesel
Post29-11-2009, 23:27    Subject: Ambient Pressure Sensor for VW G3 AFN ECU Quote
by KeeSoft wrote:
hello,
The ambient pressure sensor is integrated into the mass airflow sensor (MAF), and it can be accessed/found [here/there/etc.].
manufactured by KeeSoft
"Not applicable to the vehicle/control unit mentioned (for the initial G3 1Z models)."
(Possibly also Audi 80/A4 models with MSA12 without WFS, as there was something like that before).
@reusel:
I still have a dead MSA15 lying around. The sensor might still be working.
Micha
Translated on 23-10-2026, 5:32.
reuselkopp
Post21-03-2010, 17:52    Subject: Ambient Pressure Sensor for VW G3 AFN ECU Quote
Hello everyone,
I'm bringing this thread back to the top.
Does anyone have a working ambient pressure sensor from an MSA15 that they're not using, or does anyone know a source where I can buy one? Currently, the ambient pressure sensor is only showing 690 mbar.
Greetings.
Reuselkopp.
Translated on 23-10-2026, 5:33.
vwSchrauber
Post22-03-2010, 10:33    Subject: Ambient Pressure Sensor for VW G3 AFN ECU Quote
If it doesn't work, just install a fixed resistor. If you don't have any tuning, it shouldn't matter, and you can extend the VGZ (which is also dependent on the ATM pressure) using VCDS.
Simply measure the voltage at the STG (under voltage, open), the middle pin is usually the signal output. You can optionally solder in a potentiometer and adjust the "desired" atmospheric pressure icon_wink.gif.
Translated on 23-10-2026, 5:34.
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alternative ECU: Find the Right Control Unit On-Board Diagnostics (OBD)
No new posts Ambient Pressure Sensor: Build a Replacement Circuit On-Board Diagnostics (OBD)
No new posts B8 Variant 2.0 TDI Diesel Engine Technology
No new posts Golf 6 Variant: Heated Steering Wheel Transmission, Chassis, Body & Interior
