Successfully replaced the turbocharger solenoid valve on a 1Z engine
haehnlein
Post24-03-2003, 16:57    Subject: Successfully replaced the turbocharger solenoid valve on a 1Z engine Quote
After my Passat 1Z suddenly lost power at higher speeds and when driving uphill (entering a limp mode), I measured the boost pressure using VAG-COM, and it turned out that the boost pressure was far too high.
After receiving multiple hints here in the forum, I replaced the magnetic valve for boost pressure limitation, and lo and behold: everything is working fine again icon_razz.gif.
(Title changed - I think the main idea should be recognizable from the title itself / Best regards, Ulf)
____________
Kein Auto mehr!
haehnlein
Post24-03-2003, 22:15    Subject: Re: Successfully replaced the turbocharger wastegate solenoid valve on a 1Z engine Quote
haehnlein wrote:
(Title changed - I think we should try to make the main point recognizable from the title itself / Best regards, Ulf)
____________
Kein Auto mehr!
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injector Replacement: Tips & Experiences Diesel Engine Technology
No new posts ZR Replacement: Additional Work & Costs Diesel Engine Technology
No new posts Xenon Bulb Replacement Problems: Troubleshooting Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts GRA Installation Successful: Thanks Forum! On-Board Diagnostics (OBD)
