Question about Jaeger E-Satz Coding Audi A6 4F
schrauber2punt0
Post11-04-2010, 13:31    Subject: Question about Jaeger E-Satz Coding Audi A6 4F Quote
I have coded a Jaeger ESatz on my Audi using this guide -> http://wiki.ross-tech.com/wiki/index.php/Trailer_Hitch_Retrofitting_%284F%29
(PRE-2006 2.0 TDI)
To Point 1: Registering the control unit on the CAN bus - completed
To point 2 - nothing done as the control unit is not diagnosable
To point 3 - Trailer Stabilization - I also did this because the Jaeger steering system is supposedly designed to support it. However, I'm not entirely sure if this is actually the standard practice. Do you know this?
To setting point 4 PDC - is this superfluous if you have a detachable tow hitch? - Isn't this just about setting the distance to the obstacle? Or am I misunderstanding? An automatic PDC (Parking Assist) deactivation with the Jaeger Stg. (stage) should not function.
To point 5 - I didn't work on the engine because it's a 2.0 TDI
To point 6 - I haven't
To point 7 - I didn't either
After that, I also cleared the error memory. Perhaps someone could provide further information regarding the open points...
Karma: +437 / -0   Thank you, like it!
Post11-04-2010, 22:46    Subject: Question about Jaeger E-Satz Coding Audi A6 4F Quote
Regarding point 3: There is a sensor block in the ABS/ESP control unit that indicates whether a trailer has been attached and would then regulate accordingly (MWB 10?, but I'm not sure).
Regarding point 4: If you remove the detachable every time the hook is removed, then this is unnecessary. But it also doesn't hurt to simply encode.
Whether the Jäger-STG does not support PDC shutdown is not something I am aware of. Just try coding it into the PDC and see if any errors are introduced, or if it might actually work.
Greetings
Guste
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Trailer Hitch Coding Audi A8 - Data Bus Issue On-Board Diagnostics (OBD)
No new posts Hazet 2592 im Satz Diesel Engine Technology
No new posts I am looking for an installation manual for an electric t... Diesel Engine Technology
No new posts Rep.Satz Fensterheber Golf 4 Transmission, Chassis, Body & Interior
