Audi 2.5 TDI: Boost Issues When Downshifting.
Aq301
Post30-11-2016, 16:50    Subject: Audi 2.5 TDI: Boost Issues When Downshifting. Quote
Good day.
I have an Audi A6 C4 Quattro TDI Avant with the engine code: AEL.
My question to all drivers of these turbocharged engines with boost gauges is:
What boost pressure, for example, do you typically see on the highway when coasting in 5th or 6th gear?
Mine still shows a good half bar before the speed drops low enough.
The only explanation I have is the high airflow through the turbine.
But without accelerating?
Otherwise, the display works perfectly fine.
Best regards, Stephan.
Translated on 06-09-2026, 23:10.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post30-11-2016, 19:56    Subject: Audi TDI: Boost Issues When Coasting Quote
Good day to you too.
It's perfectly normal; the turbine doesn't stop immediately after the gas supply is cut off icon_wink.gif.
The pistons continue to move, and there is still a mass flow through the intake and exhaust passages of the engine.
You don't have a throttle valve like in a gasoline engine, otherwise the gauge would go into the vacuum range.
So, the airflow doesn't stop, and the turbocharger is still generating "some" boost pressure.
...and in doing so, you've already given yourself the correct answer.
Regards, Mpire.
Translated on 06-09-2026, 23:12.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure for Audi 100 AAT Turbo Diesel Engine Technology
No new posts Only 0.5 bar of boost pressure at idle Diesel Engine Technology
No new posts max. Boost pressure for the 115 PD AUY Diesel Engine Technology
No new posts High loading pressure? - Audi A4 1.9 TDI, manufactured in... Upload
