Doku Golf 1J, Window doesn't close (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post06-03-2003, 8:42    Subject: Doku Golf 1J, Window doesn't close Quote
The disc stops even though the switch is activated before it has closed.
Cause:
The electric window mechanism has not been properly initialized according to the regulations.
The blades are not initialized and therefore have no orientation towards the upper stop (closed position) after a power interruption, reset, replacement of the window motor, disconnecting the battery, damage, or removal of the fuse.
Solution:
Generally, the new initialization after turning on the ignition following a reset (disconnecting the battery for at least 30 seconds) should be performed as follows:
About Internal Switches:
When initializing each switch blade, the following steps should be taken:
For open slices:
Activate the "Lift" switch until the blades stop at the top stop.
Release the switch
Activate the "Lift" switch for at least 2 seconds.
Power-off switch
Similarly, initialization must be performed during the "lowering" process.
When the discs are closed:
Release the switch
Press the "Lift" switch again for approximately 2 seconds.
Also, if an electric sliding roof is present, it should also be re-initialized in the same manner.
Tschüss
Michael II
Ratings - Doku Golf 1J, Window doesn't close
No new posts Doku Transporter 7D, Schiebetüre schließt schlecht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, from 5/99, Rear door lock not working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary: Air vent nozzle cannot be closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Golf 4 - Central locking not working with key, windows cl... Transmission, Chassis, Body & Interior
No new posts The door lock no longer works in the cold. Transmission, Chassis, Body & Interior
No new posts AGR schließt nicht -> LMM Wert erreicht nie den SOllwert Diesel Engine Technology
No new posts Intake valve not closing long enough, causing engine shake! Diesel Engine Technology
