amiarts
02-08-2010, 14:36 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
Hello everyone,
"I signed up today because I'm stuck with my project of creating a digital speedometer for my Skoda Octavia. I've obtained a DIY speedometer and powered it up. It works great and displays RPM and speed when the corresponding signal is sent to the pins. However, I can't access the data with VAGCOM; I simply can't establish a connection with the individual speedometer. Is it normal that this doesn't work without additional bus devices, or am I doing something wrong?"
Thank you in advance.
René
Translated on 11-09-2026, 15:56.
02-08-2010, 15:01 Subject: OBD Adapter Skoda Octavia 1U (No CAN) |
amiarts wrote: | | Is it normal that this doesn't work without additional bus devices...? |
No, I have to go. I also built something similar, and it works.
Do you provide a voltage source for the interface and the dashboard?
Translated on 11-09-2026, 15:57.
Profile PM Garage |
amiarts
05-08-2010, 15:33 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
Yes, the power supply connections for the speedometer and the OBD module are the same. The speedometer is connected to the blue connector with pin 1 and 23 connected to positive voltage, and pin 9/24 connected to ground. The OBD connector has pin 4 and 5 connected to ground, pin 7 (K-line) connected to pin 25 on the blue connector of the speedometer, and pin 16 connected to positive voltage. Do I have any errors in my wiring somewhere?
Sure, here's the translation:
"Thank you in advance."
René
Translated on 11-09-2026, 15:58.
05-08-2010, 17:52 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
"That's how it should work."
Speedometer, blue connector:
PIN 1 = Terminal 15.
PIN 7,9,24 = Terminal 31.
PIN 23 = Terminal 30.
PIN 25 = K-line.
OBD socket:
PIN 4.5 = Terminal 31.
PIN 7 = K-line.
PIN 16 = Terminal 30.
You're missing a mass, so go ahead and attach it.
Translated on 11-09-2026, 16:00.
Profile PM Garage |
amiarts
05-08-2010, 22:33 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
Okay, Michael.
dann werde ich morgen mal noch die Gebermasse anschließen. Gute Idee. You're welcome.
René
Translated on 11-09-2026, 16:01.
amiarts
06-08-2010, 17:45 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
Hmmm.... Keine Besserung. VAGCOM findet immer noch kein Kombiinstrument. Damn.
René
06-08-2010, 19:53 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
Do you know if the speedometer can even be read? Not because it's faulty, you already said it's for tinkering with.
Is your interface/VAG COM also working correctly?
Profile PM Garage |
amiarts
06-08-2010, 20:03 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
I also think the speedometer is way off.
Then I'll have to get myself a new one to tinker with.
My interface is working fine; it functions without any problems in the car.
Thank you. Best regards, René.
Translated on 11-09-2026, 16:02.
06-08-2010, 22:31 Subject: OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) |
amiarts wrote: | | My interface is fine; it works in the car without any problems. |
Then the problem must be with the speedometer. I built mine according to the configuration mentioned above, and it works perfectly with every speedometer.
Profile PM Garage |
