Please find the log file attached.
Passat 3B, 1.9L TDI, 66kW, engine code AHH.
Postscript:
The two upper logs were run with the vacuum sensor disconnected, once in third gear and once in fourth gear.
The lower log shows a connection to a vacuum sensor labeled 'normal' and indicates the error 'Actual boost pressure too high'.
| Description: |
| Turbocharger Pressure Difference Log |
 Download |
| File name: |
LOG-01-011-dritter Gang.CSV |
| File size: |
8.74 KB |
| Downloaded: |
512 times |
| Description: |
 Download |
| File name: |
LOG-01-011-005-vierter Gang.CSV |
| File size: |
8.92 KB |
| Downloaded: |
605 times |
| Description: |
 Download |
| File name: |
LOG-01-011-004-xxx.CSV |
| File size: |
3.95 KB |
| Downloaded: |
627 times |
Translated on 29-10-2026, 5:04.
