Power Steering Noise: Causes & Fixes
bordones
Post15-01-2011, 18:58    Subject: Power Steering Noise: Causes & Fixes Quote
"Hi everyone,
My Superb 3U 77KW TDI has been making noises in the power steering system during steering movements for some time. There are no visible leaks externally. With the engine running and the power steering reservoir cap open, there's a significant amount of oil overflowing. This doesn't happen in a comparable vehicle. I've already replaced the power steering pump and the steering rack, including the check valve. Unfortunately, this didn't solve the problem. The oil overflow is still present. The parts are from TRW. I've blown out all the lines. I've noticed that there's a valve or calibration device in the return line to the power steering reservoir. I've also considered the possibility of air being drawn in, but I haven't found anything. In my opinion, the oil overflow is caused by a faulty valve. What do you think about this problem?"
Translated on 16-10-2026, 2:49.
Stummel
Post15-01-2011, 19:55    Subject: Power Steering Noise: Causes & Fixes Quote
Is the pipe bent or somehow constricted? If it's making a loud hissing/rattling noise, it could also be due to cavitation in the pump.
Translated on 16-10-2026, 2:50.
schlauchdruide
Post16-01-2011, 18:30    Subject: Power Steering Noise: Causes & Fixes Quote
If the oil isn't foaming like in your mom's soup, then you probably don't have a problem with air in the system. I also think that a faulty pressure relief valve is causing the cavitation, which is producing the noise.
Translated on 16-10-2026, 2:51.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Expansion Valve Sounds - A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Doku: Engine Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dampen power steering? Transmission, Chassis, Body & Interior
No new posts Difficult steering Transmission, Chassis, Body & Interior
No new posts Power Steering Squeal: Causes & Fixes Diesel Engine Technology
No new posts Power steering fluid change? Diesel Engine Technology
