ToniToni Guest
03-12-2009, 22:45 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
I'm having a strange issue with my Passat 1.9 TDI, manufactured in 2003, with 120,000 km on the odometer.
'Occasionally, the car doesn't start when it's warm. I turn the key, all the indicator lights come on, the starter motor turns, but there's no ignition. This can happen several times, always with the same problem. Then, suddenly, the car starts without any issues. After that, I can start it repeatedly without any problems when it's warm, until this error occurs again without warning. There are no problems while driving, and of course, not during a cold start either. Otherwise, the car has no other 'issues'.'
For me, the potential culprits are the immobilizer, the diesel pump, and the relay for the diesel pump (if there even is one). I recently replaced the battery, as it's often a cause of mysterious problems. However, unfortunately, the problem has reappeared just 14 days after the battery replacement.
'Because the error occurs very rarely and sporadically, I can't provide a more detailed description. I only have the impression that after turning the key and before starting, there's usually a brief clicking sound in the dashboard and a suction noise (from the relay - which one? - and the diesel pump in the trunk), and I don't hear these noises when I'm experiencing the starting problems. By the way, the error memory is empty.'
Does anyone have any ideas?
Translated on 21-09-2026, 0:39.
03-12-2009, 23:01 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Please specify the MKB (engine code). "1.9 TDI" is a very broad term.
Translated on 21-09-2026, 0:41.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
03-12-2009, 23:03 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Did you read the error codes? Also, the engine code is missing! Everything else is just guesswork.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
Octavia_4x4 Schrauber
03-12-2009, 23:04 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
ToniToni wrote: |
As potential causes, for me, the immobilizer, the diesel pump, and the relay for the diesel pump (does that even exist?) are possibilities. |
If the WFS (Wireless Front Sensor) is the problem, the WFS indicator light on the instrument cluster will flash. In that case, the car would briefly start and then shut off again due to an incorrect code.
The diesel pump relay itself is less likely to be the problem, but it's worth checking the relay labeled "109" (use the search function here to find "relay 109"). If that relay is faulty or causing intermittent errors, nothing will work.
And as Michael already mentioned, everything else can only be diagnosed more precisely once your engine code is known.
Translated on 21-09-2026, 0:42.
ToniToni Guest
04-12-2009, 19:07 Subject: SEO-optimierte Übersetzungen sind ohne Kontext schwierig. Hier sind ein paar Optionen, abhängig vom Inhalt:
* **Best German Recipes: Easy & Delicious**
* **German Food: Authentic Recipes & Cooking Tips**
* **German Cuisine: Traditional Dishes & How-To**
* **German Recipes: Quick, Easy & Authentic**
* **German Cooking: Simple Recipes for Beginners** |
Okay, so, according to the service booklet,
3B6 262
96kW TDI SG6
and further digits in groups of three.
I hope you can make use of this; otherwise, please don't hesitate to ask.
Thank you and best regards!
Translated on 21-09-2026, 0:44.
04-12-2009, 19:19 Subject: Engine Code: Find it in your Service Booklet |
ToniToni wrote: | So, in the service booklet, it says
3B6 262
96kW TDI SG6
Thank you and best regards! |
Well, it's not the ideal engine, but since it's a 3BG with 130 horsepower and a 6-speed transmission, it can only be an AVF. The engine code is on the sticker in the service booklet.
Translated on 21-09-2026, 0:45.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
12-12-2009, 17:25 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Hi, I'm looking for an AVF relay, model 109. Here are some search results:
/viewtopic.php?t=21174&start=0&postdays=0&postorder=asc&highlight=avf%20relay%20109
Relay 219 in the fuse box?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 21-09-2026, 0:47.
12-12-2009, 23:28 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Hey Toni, if it was the relay, please report it properly.
so that I can be happy.
and others get an important clue when searching, unlike you, who initially found nothing!
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
10-04-2010, 17:04 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Access to the relay box, Passat 3BG: And what if you ever need to remove the blind plug?
| Description: |
| File size: |
102.33 KB |
| Viewed: |
14968 times |
| Description: |
| File size: |
158.55 KB |
| Viewed: |
12662 times |
Passat Variant BGW 2005
Translated on 21-09-2026, 0:48.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
10-04-2010, 19:55 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
It could also be due to an insufficient initial speed; what is the current speed?
Profile PM WWW Garage |
D. Guest
10-04-2010, 20:31 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Low starter motor speed and defective batteries can also frequently cause warm start problems in the BKD engine (which, in this case, refers to the 2.0-liter 16V version).
10-04-2010, 21:16 Subject: Relay 219: Motor Control Unit Explained |
ToniToni wrote: |
I've done some research online: Removing the wiper arms and brackets is no problem, but the glued-on windshield deflector is supposed to be removable, ideally by breaking off the deflector itself, but in the worst case, by breaking the windshield.
I can't believe that VW installs fuses and relays in a box and then covers it up with other parts in a way that seems "professional" but is actually hiding something.
Does anyone have a clue? |
The windshield wipers and deflectors can remain in place. Nothing needs to be broken or damaged. The blind plug is located in the deflector, directly above screw number 5, which is underneath the driver's side wiper arm. Its purpose is to allow access to this screw. I took the photos to eliminate any ambiguity.
Drive the wiper to its uppermost position, turn off the ignition. Reach under the wind deflector and push the plug upwards. This clears the way for a quarter-inch tool. Directly below the hole that is now visible is screw number 5.
Translated on 21-09-2026, 0:50.
25-08-2010, 20:14 Subject: Passat TDI: Starting Problems - Troubleshooting Guide |
Unfortunately, the original poster did not implement any of the suggestions provided. I hope this topic helps readers who are able to implement these suggestions and who are grateful for such assistance, while also allowing them to filter out the irrelevant content.
Translated on 21-09-2026, 0:51.
