Doku Golf 1J MJ 99, Interior lights are dim (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post06-03-2003, 9:06    Subject: Doku Golf 1J MJ 99, Interior lights are dim Quote
Interior lights only illuminate in vehicles with an alarm system and interior monitoring.
Cause:
The vehicle was fully locked and then, within 30 seconds, the rear door was reopened. As a result, all interior lights can illuminate.
Only models from 1999 with interior monitoring are affected. After approximately 70 minutes, the interior lights will turn off.
Solution:
Remove the front interior light.
Disconnect the power cord of the interior light and plug in adapter cable No. 1J0 971 371 B.
Reinstall the interior light and check the function.
Tschüss
Michael II
Ratings - Doku Golf 1J MJ 99, Interior lights are dim
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J bis KW 16/98, Knackgeräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 12/00: Whistling noises from ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy interior lights On-Board Diagnostics (OBD)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Brake caliper-wheel bearing holder, Golf 2 GTD and Golf 1... Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 4 6-Gang TDI Gearbox for Golf 3 TDI Diesel Engine Technology
