2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise under partial load (Solution)
Post11-08-2010, 11:17    Subject: 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise under partial load Quote
To: Rainer K.
Written on: 2010-08-11 9:39
Title: Article for Error/Knowledge Bases
I have a helpful suggestion for the error/knowledge databases.
Engine: 2.0 TDI BKD/AZV, from 2004, in all VAG models.
Error: Whistling/squealing noise in the partial load range, apparently indicating turbocharger damage.
Cause: Hairline crack/constant vibration breakage in the connecting pipe between the manifold and the exhaust cooling system, specifically in the area of the corrugated flexible section. Exhaust gases escape under certain load conditions, and as they pass through the resulting gap, they produce the noises.
Solution: The relevant pipe was structurally redesigned and modified with an inlet.
to prevent fractures.
Thank you very much!
Ratings - 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise under partial load
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 7 2.0 TDI - Hesitation/Misfire at Partial Load Diesel Engine Technology
No new posts Loud hissing sound during acceleration / 2.0 TDI Diesel Engine Technology
No new posts BMP exhibits shaking behavior in partial load range / Dom... Diesel Engine Technology
No new posts Golf TDI: Turbo Whistle in Partial Load? Diesel Engine Technology
