Climate compressor making noise
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Crissi
Post29-06-2010, 12:03    Subject: Climate compressor making noise Quote
'On my 2005 Caddy with a 1.9 TDI engine, the AC compressor is likely making some strange noises. It's a fairly loud metallic clacking sound that occurs sporadically shortly after starting the engine, regardless of whether the Climatic system is on or off. The Climatic system itself was working... until yesterday.'
'I briefly removed the right inner fender to check which brand of compressor was installed. I then also removed the ribbed belt, started the engine for a short time (without the belt), and let it run for a minute or two. Finally, I put everything back together.'
This morning, the heating stopped working and couldn't be turned off or adjusted at all (which was great in this heat).
Is there any connection between running the engine without the serpentine belt and error messages appearing on the Climatic system?
Help would be appreciated... in this heat!
Best regards, Criss.
Translated on 22-07-2026, 23:31.
Octavia_4x4
Post02-07-2010, 18:23    Subject: Climate compressor making noise Quote
You could at least start by reading the error codes from the Climatic system; it's already capable of diagnostics.
Perhaps this will provide a direction to start searching.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Translated on 22-07-2026, 23:36.
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K bis 04/96, Trommelbremse macht Geräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document Transporter 7D, vacuum pump making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate compressor makes a grinding noise Transmission, Chassis, Body & Interior
No new posts TDI Belt Drive Noise: Causes & Solutions Diesel Engine Technology
No new posts Climatronic Blower Motor Noise: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Klimakompressor VR6 Diesel Engine Technology
