When opening the doors, a snapping or clicking sound occurs.
Cause:
Due to insufficient clearance between the roof trim and the door frame, the smooth surface of the roof trim may adhere (stick) to the door frame. When the door is opened, the roof trim can detach and snap or clap back with a noise. This issue is particularly likely to occur in dry weather.
men.
Solution:
There should be a clearance of 1-2 mm between the top trim and the door frame.
to be available.
By making slight adjustments to the angle at which the roof trim is installed...
Approximately 1 mm of clearance can be achieved by moving the component downwards.
For making corrections, a piece of wood or plastic is suitable.
approximately 150 mm x 20 mm in size. Caution: Avoid peeling of the paint!
Tschüss
Michael II
Translated on 29-10-2026, 14:17.
