eric_hahn
Joined: 05/08/2010 Posts: 4 Karma: +0 / -0 Location: Noervenich
08-05-2010, 23:09 Subject: ASR Issue: Audi 8D/B5 Questions |
Hello everyone.
I've really searched everywhere to get information...
I now own an A4 Avant 2.5 TDI, manufactured in November 1998, and I have a question about the ASR (Anti-Slip Regulation) system.
"In my center console, there's a switch for ASR (Anti-Slip Regulation). However, there's no indicator light in my dashboard. When I press the switch, shouldn't there be a light somewhere that shows me that ASR is now turned off?"
Even when I turn on the ignition, the ASR light doesn't come on; only the airbag and ABS lights illuminate.
I would like to know if the car has ASR (Anti-Slip Regulation) or if the switch is just a dummy.
When I access the ABS control unit using VAG-COM, it displays "ABS/ASR Front."
No error codes found in the fault memory.
Can anyone help me with that? That would be very kind.
Translated on 25-10-2026, 8:18.
09-05-2010, 9:22 Subject: ASR Issue: Audi 8D/B5 Questions |
Please perform a complete vehicle scan.
Translated on 25-10-2026, 8:20.
Profile PM WWW Garage |
eric_hahn
13-05-2010, 16:58 Subject: ASR Issue: Audi 8D/B5 Questions |
Hello, it took a while, but I hope this is what you need.
Address: 01
Protocol: KW1281
Controller: 8D0 907 401 H
Component: G00SG D42
Encoding: 02002
Workshop code: WSC 06325.
Address: 03
Protocol: KW1281
Controller: 8E0 614 111 H
Part: ABS/ASR 5.3 FRONT D10
Coding: 00012
Workshop code: WSC 06435.
Address: 08
Protocol: KW1281
Controller: 8L0 820 043 D
Part: A4 CLIMATE FULL AUTOMATIC SYSTEM_D75
Coding: 04163
Skipping Address, 15 Airbags.
Address: 17
Protocol: KW1281
Controller: 8D0 919 880 MX
Bauteil : B5-KOMBIINSTR. VDO D10
Coding: 04060
Workshop code: WSC 33073.
Translated on 25-10-2026, 8:22.
heizfoss Blaumann
Joined: 01/02/2006 Posts: 42 Karma: +4 / -1 Location: süddeuschland
13-05-2010, 20:39 Subject: ASR Issue: Audi 8D/B5 Questions |
Okay, the text from your excerpt clearly indicates:
Address 03.
Protocol: KW1281.
Encoding: 00012
You have an ABS/ASR 5.3 system, which is made by Bosch. It has ASR (Anti-Slip Regulation) but not ESP (Electronic Stability Program).
It's possible that there wasn't a separate lamp back then (other than the ABS lamp).
I'm not sure about that, but if it's important, we might be able to find out.
You'll notice whether the ASR (Anti-Slip Regulation) is working pretty quickly; just try it out by putting some load on the drive axle.
smooth/wet surfaces and then accelerate properly  .
heating fossil.
Spritsparen durch Ausnutzen der Querbeschleunigung - lieber tot als Schwung verlieren
Translated on 25-10-2026, 8:25.
13-05-2010, 21:05 Subject: ASR Issue: Audi 8D/B5 Questions |
Sure.
Translated on 25-10-2026, 8:26.
eric_hahn
04-08-2010, 9:18 Subject: ASR Issue: Audi 8D/B5 Questions |
Hello everyone,
I need to ask about the ASR again.
As you can see in the vehicle scan, the car should have ASR.
It didn't, though... and no one can tell me anything.
Could it be that the ASR (Anti-Slip Regulation) was simply deactivated in the control unit?
Is this possible?
You can program just about anything!
Eric.
Translated on 25-10-2026, 8:27.
04-08-2010, 9:32 Subject: ASR Issue: Audi 8D/B5 Questions |
I don't understand why you don't just post the VCDS Autoscan here. I mean, what's the point of doing something else when you're asked to do something specific, especially if it just creates more work?
VCDS, for example, indicates in the corresponding measuring block (3) whether the ASR switch has been activated or not, etc.
Translated on 25-10-2026, 8:28.
eric_hahn
05-08-2010, 19:14 Subject: ASR Issue: Audi 8D/B5 Questions |
Vehicle model: 8D - B5 Audi A4.
Scan: 01, 02, 03, 08, 15, 17, 25, 35, 45, 46, 55, 56
Address 01 -------------------------------------------------------
Control unit: 8D0 907 401 H
Encoding: 02002
1 error code found.
18259 - Data bus fault: No message received from the ABS control unit.
P1851 - 35-00 - -
Readiness: Not available.
Address 03 -------------------------------------------------------
Control unit: 8E0 614 111 H
Coding: 00012
0 error codes found.
Address 08 -------------------------------------------------------
Control unit: 8L0 820 043 D
Coding: 04163
Address 17 -------------------------------------------------------
Control unit: 8D0 919 880 MX
Coding: 04060
VEHICLE IDENTIFICATION NUMBER: AUZ7Z0Y1517103
Address 25 -------------------------------------------------------
Control unit: Please specify the address.
Component: Enter e 17.
No error codes found.
or error codes are not supported by the control unit.
or a transmission error has occurred.
Address 35 -------------------------------------------------------
Control unit: 8L0 862 257 K
Component: Central locking pump, radio. D06.
Encoding: 12896
End -------------------------------------------------------
Translated on 25-10-2026, 8:32.
