Fresh Paint: When to Polish?
Go to page: 1, 2  Next
Post18-10-2010, 14:21    Subject: Fresh Paint: When to Polish? Quote
Hi.
I just painted a small scratch (metallic paint with clear coat).
When is the earliest I can use a color touch-up to blend the roots a little?
Translated on 31-08-2026, 16:53.
Post18-10-2010, 14:33    Subject: Fresh Paint: When to Polish? Quote
How should I apply the paint? With a spray can or a spray gun? And do I need to sand the surface first?
Post18-10-2010, 15:02    Subject: Fresh Paint: When to Polish? Quote
The drying time is highly dependent on temperature, so please be cautious given the current temperatures.
At 20°C, with properly mixed automotive paint (hardener, thinner, and paint) and a normal layer thickness, you can expect approximately 1 day of drying time. The exact data is usually provided in the processing instructions for each specific product.
The spray can from the hardware store works a bit faster, but it's only suitable for temporary, low-cost solutions.
Translated on 31-08-2026, 16:55.
Post18-10-2010, 17:18    Subject: Fresh Paint: When to Polish? Quote
Can in the heated garage icon_wink.gif.
Should the edges be sanded with 600 grit sandpaper or something similar?
I was planning to treat it only with red and white polishing compound.
But even with just the initial layers, it already looks better than the previous state, which was "scratched except for the primer."
Translated on 31-08-2026, 16:57.
Karma: +1102 / -0   Thank you, like it!
TDI-GTI-4-Motion likes this.
Post18-10-2010, 17:47    Subject: Fresh Paint: When to Polish? Quote
"Apply in a thin, even coat, and wait at least 24 hours before proceeding. If you're particular, give the paint an extra day to dry. You could also try parking it near a heater."
Post18-10-2010, 18:23    Subject: Fresh Paint: When to Polish? Quote
dieselmartin wrote:
Do you sand the edges with 600 grit or something similar?
NO! You'll never get it smooth again. Do it the way Hutfahrer says, that's 100% correct. icon_wink.gif
Translated on 31-08-2026, 16:58.
Post18-10-2010, 20:48    Subject: Fresh Paint: When to Polish? Quote
Where can I get some 2000s [clothes/items]?
I guess I'll have to search here... or maybe I'll ask Volkswagen icon_smile.gif.
Since the garage is going to be cooler again anyway, I'd rather do it at the end of the week.
Thank you.
Translated on 31-08-2026, 16:59.
Post18-10-2010, 21:07    Subject: Fresh Paint: When to Polish? Quote
dieselmartin wrote:
Where can I get some 2000s?
It's actually found in almost every public restroom, in roll form. *loud laugh* icon_lol.gif
No, you can usually find it at any accessory supplier (like Stahlgruber, Leise, etc.). I mean, I've even seen some in hardware stores.
P.S. A grit of 1600 is also fine, but you might need to polish it for about 2 seconds longer. icon_wink.gif
Translated on 31-08-2026, 17:00.
Post19-10-2010, 6:01    Subject: Fresh Paint: When to Polish? Quote
And: Use plenty of water, and rinse away the sanding dust frequently, and rinse the paper thoroughly! It's best to use a soft block of foam rubber as a sanding aid. Place the paper on top of it. It provides some pressure, but it doesn't pose the risk of sanding in the edges.
By the way, "2000 grit" (Koernung) is the finest sandpaper you can still easily buy, for example, at a hardware store. Be patient when sanding, wash it frequently, and check the results. You can use polishing paste (even a mild one) afterwards, but only when you're finished with everything else!
Translated on 31-08-2026, 17:01.
mullemaus
Post19-10-2010, 22:48    Subject: Fresh Paint: When to Polish? Quote
You can then use polishing paste (even a very mild one!). But only after you have finished everything!
You'll have to go over it with a polishing finish anyway, as those areas will become slightly dull. Even with a 2000 grit icon_wink.gif.
Translated on 31-08-2026, 17:02.
Post20-10-2010, 5:21    Subject: Fresh Paint: When to Polish? Quote
That's right! icon_redface.gif I actually meant that the paste should only be applied after the sanding is finished. As a final "finish," so to speak...
Translated on 31-08-2026, 17:03.
Post21-10-2010, 13:36    Subject: Fresh Paint: When to Polish? Quote
I once polished something with a 2000-grit abrasive in a less conspicuous spot.
The red and white paste doesn't give a glossy finish anymore; it remains matte.
Therefore, I'll leave it as it is for now (at least it's blue and not that primer beige anymore), and let nature take its course. It's right in front of the wheel arch, so it's in the most likely place to get dirty anyway.
Thank you for all your help.
Translated on 31-08-2026, 17:04.
Post21-10-2010, 13:45    Subject: Fresh Paint: When to Polish? Quote
dieselmartin wrote:
The red and white paste won't get shiny anymore; it will remain matte.
Post21-10-2010, 19:39    Subject: Fresh Paint: When to Polish? Quote
Oh... Kay.
Then I have to go shopping again icon_smile.gif.
Does she have a first name?
Translated on 31-08-2026, 17:05.
Post21-10-2010, 19:49    Subject: Fresh Paint: When to Polish? Quote
Polishing paste PLUS.
3M Part Number: 50417
Cap color: Green.
Cost: Approximately 40€ per kilogram, unfortunately, it's only available in kilogram-sized bottles.
Eigentlich is das aber machinel zuverarbeitende Politur. Bei kleinen Stellen gehts aber auch mit der Hand, dann aber gut aufdrücken und schnelle Bewegungen ausführen. Wenn du damit zu langsam arbeitest, macht das Zeug dir Kratzer ohne Ende in Lack. ASo, be careful!
My tip: Go to your local paint shop, and give the person there a 10-euro bill; it usually works. icon_wink.gif
Translated on 31-08-2026, 17:06.
Post22-10-2010, 6:15    Subject: Fresh Paint: When to Polish? Quote
Michael wrote: My tip: Go to your local paint shop, and give the guy a 10-euro bill, it usually works.
Okay! That's the most economical solution. The painter will be concerned about their (good?) reputation and will want to deliver a good result, even on such minor jobs.
No new posts Catalunya: Are They Painted? Transmission, Chassis, Body & Interior
No new posts When should I set the AGR? Diesel Engine Technology
No new posts Oil Overfill: When Is It Harmful? Diesel Engine Technology
No new posts Nozzle swap when?? T4 TDI ACV, 230,000 km Diesel Engine Technology
