VW Touareg AWD Control Module: Access Code?
snowman24
Post13-08-2010, 19:33    Subject: VW Touareg AWD Control Module: Access Code? Quote
Hello everyone,
I've changed the topic now because the original question had been clarified.
However, I am still looking for the access code for the control unit for the transfer case.
Where can I get this?
Without this, I can't run the actuator diagnostics.
Greetings.
Marcus.
Translated on 04-08-2026, 3:24.
snowman24
Post26-08-2010, 19:56    Subject: VW Touareg AWD Control Module: Access Code? Quote
Does anyone have any ideas?
Greetings.
Marcus.
Translated on 04-08-2026, 3:25.
Karma: +808 / -0   Thank you, like it!
Post26-08-2010, 21:56    Subject: VW Touareg AWD Control Module: Access Code? Quote
Hello Marcus,
Please wait, I can't find any information about that right now, but I will look elsewhere tomorrow.
snowman24
Post27-08-2010, 10:31    Subject: VW Touareg AWD Control Module: Access Code? Quote
Hello Rainer,
Sure, no problem. Here's the translation:
'Thank you in advance.'
I would like to test the servo motor for the VTG (Viscous Torque Generator) of my Touareg while it's removed, to see if it's still running smoothly, as I repeatedly experience tension issues in the drivetrain when driving around curves.
It's particularly bad when turning left.
Greetings.
Marcus.
Translated on 04-08-2026, 3:26.
Post02-09-2010, 8:30    Subject: VW Touareg AWD Control Module: Access Code? Quote
Sebastian from Ross-Tech has provided me with the following information:
Subject: Forum // Touareg All-Wheel Drive Control Unit 0AD 927 755 - Access Code?
Hello Rainer,
I'm sending this to you in this way because of historical reasons.
I don't have an active account in your forum.
Im obigen Thema fragt ein Kunde nach einem Zugriffscode. From something I...
For an unclear reason, the customer assumes that this is their problem.
would resolve the issue, but the control unit in question does not actually support that function.
Actuator diagnosis: This is why VCDS likely only offers this feature as a button.
shows as inactive. Presumably, the user therefore assumes that they can do this.
enable, but that is not the case.
The engine to be inspected is likely the V253 model, which will be...
only checked within the measurement data blocks. A control signal is recommended.
The original tester used a "direct" connection of 12V to the corresponding terminals.
Pins.
Sebastian.
Translated on 04-08-2026, 3:29.
snowman24
Post03-09-2010, 15:52    Subject: VW Touareg AWD Control Module: Access Code? Quote
Hello Rainer,
Thank you very much for that.
Until yesterday, I was of the opinion that...
as VW also states in its documentation,
It involves a 'stepper motor'.
When I removed the engine yesterday,
I was quite surprised.
It's a standard windshield wiper motor without a gearbox.
At the front, there is a multi-stage planetary gear system, and following that...
Planetary gearboxes feature a mode selection switch, similar to those found in VCRs.
This 'landing gear position switch' was the culprit behind all the stress in the landing gear assembly.
A little contact cleaner worked wonders!
I'm going to buy a motor from eBay anyway and use it to record the data of the switch, then I'll start searching for the manufacturer.
For comparison's sake: Similar switches are installed in almost every video recorder.
These cost approximately €10-€20 and no more than that.
The engine - and now brace yourself - costs €1200 at Volkswagen.
Anyway, thank you for your help.
Have a great weekend and best regards.
Marcus.
Translated on 04-08-2026, 3:33.
Post03-09-2010, 17:18    Subject: VW Touareg AWD Control Module: Access Code? Quote
Thank you for the feedback!
Translated on 04-08-2026, 3:35.
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking brake - All-wheel drive Diesel Engine Technology
No new posts AFN All-Wheel Drive: Pre-Pump Issues? Diesel Engine Technology
No new posts ARL TDI 4x4: My Experience with the 1.9 TDI 150 HP Engine Diesel Engine Technology
No new posts Coding Golf4 TDI all-wheel drive and 2WD in the engine co... On-Board Diagnostics (OBD)
