Warning buzzer in the Volkswagen Golf 2
ollli
Post07-08-2010, 20:10    Subject: Warning buzzer in the Volkswagen Golf 2 Quote
Hello diesel mechanics.
Okay, here's the translation:
"I have a question for you. I recently installed a new central electrical system in my Golf 2. Where do I connect the parking lights to the central electrical system for the left and right front sides? Ideally, could you tell me which wires to use? Is the ground wire or the positive wire connected for the parking lights? The parking lights work in the rear. I've measured at terminals L3 and L4 on the connector, but there's no activity. My VW warning buzzer relay (Relais 36) isn't making any noise either." icon_sad.gif
The interior lighting is working perfectly. Also, I now have a wiring harness from a Golf 3 TDI installed, and I can't find the wire for the front parking lights.
Could you give me some advice on that?
Best regards.
Olli.
Translated on 11-07-2026, 20:50.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post11-08-2010, 17:27    Subject: Warning buzzer in the Volkswagen Golf 2 Quote
Can you make anything of this?
-->*click*
"Let's talk about something a bit off-topic."
When will your vehicle be roadworthy again?
Translated on 11-07-2026, 20:51.
ollli
Post12-08-2010, 12:50    Subject: Warning buzzer in the Volkswagen Golf 2 Quote
Hello.
Thank you for the tip.
My Golf is getting a used G60 driveshaft today. Then I'm going to clean and tidy up the car, and after that, I'll take it to the TÜV (German technical inspection).
Best regards.
Olli.
Translated on 11-07-2026, 20:52.
ollli
Post13-08-2010, 17:24    Subject: Warning buzzer in the Volkswagen Golf 2 Quote
ollli wrote:
Hello.
I've installed the buzzer, and it works great. I also connected the parking light according to this plan. Now, I'm missing a small housing for the parking light that screws into the reflector of the headlight. Do you happen to have something like that available?
Best regards.
Olli
Translated on 11-07-2026, 20:53.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Is it possible to retrofit a VE-ESP system from a Golf 4 ... Diesel Engine Technology
