Should I remove the DPF from my Audi A4 170 hp TDI?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post18-09-2010, 20:55    Subject: Should I remove the DPF from my Audi A4 170 hp TDI? Quote
Hello.
Is it possible to simply remove the DPF (Diesel Particulate Filter) from a car in Germany and replace it with a pipe? Wouldn't the engine control unit (ECU) normally need to be adjusted? Normally, the engine should then become significantly more responsive and, at the same time, more fuel-efficient?
Has anyone here ever done that before...?
Best regards.
Tom.
Audi SQ5 8R Cvub
Back to top Profile PM Email
Karma: +1099 / -0   Thank you, like it!
Post18-09-2010, 21:57    Subject: Should I remove the DPF from my Audi A4 170 hp TDI? Quote
Feasible, but technically complex. While it may be practical, such a modified vehicle is no longer street legal, as it loses its operating permit due to the significant alterations.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Remove Stickers: Easy Guide & Tips Transmission, Chassis, Body & Interior
No new posts OM611 ESP entfernen Electrical Systems, Vehicle Electronics, Multimedia
No new posts Headlight Blends Removal: How-To Guide Transmission, Chassis, Body & Interior
No new posts Remove exhaust for test drive? Diesel Engine Technology
