07-09-2010, 11:13 Subject: TDI V157: Is it really dead? |
Hi.
Have I understood correctly that the swirl flaps (V157) are installed in the CAYx engine but not activated?
Are they stocked up for EU6, or did you just happen to have some on hand?
Can someone take a picture of the intake manifold?
Thank you.
Martin.
Translated on 07-08-2026, 5:11.
Profile PM Garage |
vwSchrauber Profi-Schrauber
10-09-2010, 13:43 Subject: TDI V157: Is it really dead? |
Yes, I once took some photos of a CAY, and I think I saw something similar there as well. I'll try to find them for you  .
Translated on 07-08-2026, 5:12.
10-09-2010, 14:02 Subject: TDI V157: Is it really dead? |
Here are the pictures...
Regarding the current clamp: I was curious whether it uses piezoelectric elements or not. The devices look structurally similar to the "old" magnetic valve injectors from Bosch.
| Description: |
 Download |
| File name: |
IMG_0231.jpg |
| File size: |
2.64 MB |
| Downloaded: |
1910 times |
| Description: |
 Download |
| File name: |
IMG_0229.jpg |
| File size: |
2.49 MB |
| Downloaded: |
2026 times |
Translated on 07-08-2026, 5:13.
10-09-2010, 14:18 Subject: TDI V157: Is it really dead? |
Thank you.
Hmm, you can clearly see the V157 in the first picture, but it's not clear if it's connected.
Profile PM Garage |
10-09-2010, 14:19 Subject: TDI V157: Is it really dead? |
You're asking a little too late. If I still had it in the workshop, I could have connected an oscilloscope to see if it's being powered on correctly.
Translated on 07-08-2026, 5:14.
10-09-2010, 14:25 Subject: TDI V157: Is it really dead? |
Yes, it's definitely connected, at least electrically. I can't tell you about the SW connection; I don't know yet how to access that on this Conti system...
I have marked the plug in the picture for you  .
| Description: |
| CAY? Motor, V157 nicht angeschlossen |
 Download |
| File name: |
IMG_0231_m.jpg |
| File size: |
1.21 MB |
| Downloaded: |
1835 times |
10-09-2010, 14:43 Subject: TDI V157: Is it really dead? |
I still can't recognize the connector (it's my first time seeing a CAY).
Okay, well, it's possible that it's not being targeted.
The control signal could be seen in the diagnostic data.
At least, I can see my on/off swirl flaps there.
Unfortunately, the *.CLB files are not easily readable.
Translated on 07-08-2026, 5:15.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
10-09-2010, 14:51 Subject: TDI V157: Is it really dead? |
According to SSP 442, page 14, the motor V157 and potentiometer G336 are currently non-functional and not integrated into the self-diagnostic system.
Translated on 07-08-2026, 5:16.
Profile PM Garage |
10-09-2010, 16:12 Subject: TDI V157: Is it really dead? |
One should also read some sentences to the end  .
Profile PM Garage |
vagtuning Guest
10-09-2010, 19:37 Subject: TDI V157: Is it really dead? |
Oh, changing the valve cover gasket there is definitely going to be a lot of fun.
Sorry for the off-topic comment.
Translated on 07-08-2026, 5:17.
Profile PM Garage |
11-09-2010, 10:51 Subject: TDI V157: Is it really dead? |
Why would you need to replace the valve cover gasket? The timing belt is changed every 300,000 km (as far as I know), and the valve cover doesn't necessarily have to be removed at the same time.
Besides that: a valve cover gasket on a VW doesn't usually leak  .
Translated on 07-08-2026, 5:18.
vagtuning Guest
11-09-2010, 14:09 Subject: TDI V157: Is it really dead? |
Timing belt replacement every 180,000 km.
11-09-2010, 18:03 Subject: TDI V157: Is it really dead? |
Okay, I seem to have been mistaken – but surely there hasn't been a CR-TDI engine with a 300,000 km service interval for very long?
Octavia_4x4 Schrauber
11-09-2010, 20:23 Subject: TDI V157: Is it really dead? |
vwSchrauber wrote: | | Okay, then I was mistaken about that - but isn't there a certain CR-TDI model that has only been around recently, which has a 300,000 km service interval? |
Our 1.6 CR TDI engine in the Octavia 4x4 with 105 horsepower... I don't recall the engine code right now.
Translated on 07-08-2026, 5:19.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
11-09-2010, 21:42 Subject: TDI V157: Is it really dead? |
I can't find a Skoda Octavia 4x4 with a 1.6 engine; I only find the CAYC version with two-wheel drive and a 210,000 km service interval.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 07-08-2026, 5:20.
Profile PM Email Garage |
