Should I remove the DPF from my Audi A4 170 hp TDI?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post18-09-2010, 20:55    Subject: Should I remove the DPF from my Audi A4 170 hp TDI? Quote
Hello.
Is it possible to simply remove the DPF (Diesel Particulate Filter) from a car in Germany and replace it with a pipe? Wouldn't the engine control unit (ECU) normally need to be adjusted? Normally, the engine should then become significantly more responsive and, at the same time, more fuel-efficient?
Has anyone here ever done that before...?
Best regards.
Tom.
Audi SQ5 8R Cvub
Back to top Profile PM Email
Karma: +1098 / -0   Thank you, like it!
Post18-09-2010, 21:57    Subject: Should I remove the DPF from my Audi A4 170 hp TDI? Quote
Feasible, but technically complex. While it may be practical, such a modified vehicle is no longer street legal, as it loses its operating permit due to the significant alterations.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Schweinwerferblenden entfernen!! Transmission, Chassis, Body & Interior
No new posts OM611 ESP entfernen Electrical Systems, Vehicle Electronics, Multimedia
No new posts Remove Stickers: Easy Guide & Tips Transmission, Chassis, Body & Interior
No new posts ABS/ESP Control Unit: Remove Brake Pad Sensor On-Board Diagnostics (OBD)
