@Ulf Topic: Chip tuning and 10-cent optimization
Marko
Post15-04-2002, 12:39    Subject: @Ulf Topic: Chip tuning and 10-cent optimization Quote
Hi Ulf!
Here we go again, back to the same topic.
I took a look at your link, and it's well-written.
How much further can I advance the start of the injection?
Can you give me some target values that should not be exceeded?
Sure, here's the translation:
"I would be grateful!"
"Could you please send me your email address just in case, as I'm still trying to locate the resistor or capacitor. (A6 C4 TDI, AAT)"
STG: 55-pin connector pin assignments.
Cu: Marko
Post15-04-2002, 18:37    Subject: Start of spraying Quote
Hi Marko,
-- How much further can I delay the start of the injection? --
Do not adjust the capacitor beyond the setting that corresponds to the pure speed advance (see also the pump link on Rainer's website).
"Can you give me some target values that should not be exceeded?"
I'm currently trying it out myself. The equivalent series resistance (ESR) still plays a role with 1µF compared to 100 nF.
I want to try and see when the NBF signal stops being detected altogether. It might still take some time...
-- Just in case, could you send me your email address? --
ubeck13 at aol.com
-- as I'm still searching for the location of the resistor or capacitor. (A6 C4 TDI, AAT engine)
STG: 55-pin connector pin assignments --
Is the AAT the 2.5L 5-cylinder engine?
Best regards, Ulf.
Marko
Post15-04-2002, 21:41    Subject: @Ulf Topic: Chip tuning and 10-cent optimization Quote
Hi Ulf!
Yes, it's still the old 5-cylinder engine with 115 horsepower.
Here's a picture of my engine control unit (ECU) so you can see where the capacitor is located, since I'm not sure myself.
cu: Marko
No new posts Car books, repair manuals, and tools Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts 10Cent Tuning Technical Articles
No new posts Chip + 10 cent getestet Diesel Engine Technology
No new posts Delayed broadcast for 10 cent tuning Diesel Engine Technology
No new posts 10 cent Tuning für alle TDI`s und wie ist es besser ??? Diesel Engine Technology
No new posts 10 or 20 cent tuning for PD engine (ASZ) On-Board Diagnostics (OBD)
