holzbein Blaumann
18-09-2010, 19:34 Subject: AGR Valve Calibration: How-To Guide |
Hello fellow enthusiasts,
I replaced the AGR valve on a Skoda Fabia I, type 6Y. After a short time, the following error appeared:
"One error found:"
16786 - Exhaust gas recirculation system: Flow rate too high.
P0402 - 35-00 - -
"With this error, the EGR valve is (usually) not activated and remains fully open. I personally doubt this is the case with a new valve, and according to the AUTO-LOG, it is being activated."
According to Pieburg, an EGR valve should also be programmed. Does this make sense, and if so, how is it done with VAG-COM?
Thank you very much.
Translated on 24-09-2026, 17:36.
18-09-2010, 19:43 Subject: AGR Valve Calibration: How-To Guide |
Engine type? Gasoline or diesel? MfG. Michael
Translated on 24-09-2026, 17:37.
Profile PM Garage |
chli1976 Profi-Schrauber
18-09-2010, 19:52 Subject: AGR Valve Calibration: How-To Guide |
Check if anything works with the default setting of 074. VCDS
holzbein Blaumann
19-09-2010, 11:09 Subject: AGR Valve Calibration: How-To Guide |
Engine code: BBY, 1.4 gasoline.
How does a basic calibration process generally work? Do I need to specify target values under certain conditions, or does the actuator adjust itself automatically after a certain amount of time?
