pa-mm6 Blaumann
27-01-2008, 11:55 Subject: Fuel Pressure Sensor for Tandem Pump |
Hello.
I read in the SSP that there is supposed to be a connection for pressure measurement on the tandem pump of PD TDI engines. Is it possible to connect a fuel pressure sensor, for example from VDO, here? If so, does anyone happen to know what thread is used here, perhaps M10x1, like with the oil pressure sensor?
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 05-09-2026, 19:08.
Profile PM Email |
pa-mm6 Blaumann
02-02-2008, 11:04 Subject: Fuel Pressure Sensor for Tandem Pump |
Hi.
Here's a little help: The VAS test device for tandem pumps, model 5187, is connected to the tandem pump connection. I plan to tap into the fuel pressure using a VDO pressure sensor, which is also used for oil pressure. Therefore, it's important to know what thread to use. Most pressure sensors have an M10 x 1 thread, although I can't determine this for the fuel pressure screw yet.
Thank you very much for your suggestions.
Audi SQ5 8R Cvub
Translated on 05-09-2026, 19:09.
Profile PM Email |
charlyfirpo Blaumann
Joined: 09/02/2006 Posts: 155 Karma: +6 / -0 Location: DM 2013 Volkswagen Golf Support
02-02-2008, 18:11 Subject: Fuel Pressure Sensor for Tandem Pump |
Hello.
I've checked the pressure several times on mine, but unfortunately, I can't tell you what kind of thread the screw has. However, I can give you a small tip.
Just try unscrewing it and measuring afterwards  .
I don't quite understand the meaning. If your engine is working fine, there's no point in constantly measuring things.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 05-09-2026, 19:10.
Profile PM Garage |
pa-mm6 Blaumann
02-02-2008, 18:15 Subject: Fuel Pressure Sensor for Tandem Pump |
hi
I have a problem with my MFA.
Connection for a gasoline pressure sensor or a diesel pressure sensor; I'd also like to connect that. I'll test the thread.
Audi SQ5 8R Cvub
Translated on 05-09-2026, 19:11.
Profile PM Email |
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
20-09-2008, 20:10 Subject: Fuel Pressure Sensor for Tandem Pump |
You can order the hollow screw for the tester from Freundlich under the part number VAS 5187A or ASE 404 520 01 000 for approximately 16 euros. It includes copper sealing rings. Then, you take this part to a local hydraulics specialist (we call them Simpex) and purchase a fitting for the hollow screw and a pressure hose up to 10 bar, and have the whole thing crimped. Don't try to use hose clamps; it won't work. You can then attach a pressure gauge or your VDO measuring device to the other end.
Passat Variant BGW 2005
Translated on 05-09-2026, 19:12.
Bertil Profi-Schrauber
20-09-2008, 20:44 Subject: Fuel Pressure Sensor for Tandem Pump |
Why is this thread being resurrected after seven months?
Translated on 05-09-2026, 19:13.
21-09-2008, 6:45 Subject: Fuel Pressure Sensor for Tandem Pump |
"Because yesterday I was looking for information on how to measure fuel pressure, I found this thread, and I knew the answer. I just wanted to help."
I will pay attention to the date in the future.
Stummel Guest
10-10-2010, 21:53 Subject: Fuel Pressure Sensor for Tandem Pump |
Even though it's really old... I just found this topic through Google.
In the parts list, the end cap screw is labeled 'M12x1.5x12'.
Test gauge with pressure gauge and air hose from the compressor + hose clamps, works perfectly... you just shouldn't use any cheap junk from the hardware store (10 clamps for €1.50...).
Translated on 05-09-2026, 19:14.
