A3 8P Alarm: Gateway Issues & Error Solutions
NoSleep
Post26-09-2010, 15:12    Subject: A3 8P Alarm: Gateway Issues & Error Solutions Quote
I've been having problems with my A3 2.0T (built in 08/2005) for a long time.
It occasionally, but frequently, triggers a false alarm after being parked.
The error message indicates that the source of the problem is device 18 (the gateway).
Furthermore, I have many communication-related errors stored in the error memory.
Since my used car warranty is about to expire, I really need to resolve this issue. Unfortunately, for almost a year now, no one has been able to accurately diagnose the problem.
Do you have any idea what might be causing this?
I found a thread where someone attributed the error to the control unit. However, it concerns a Touran. Could the same be true for my A3?
/viewtopic.php?t=6825
If anyone has any ideas about where these errors might be coming from and how to best fix them, I would be very grateful!
First, the sources of alarms:
Code:
Dienstag,14,September,2010,20:02:39:48582
VCDS Version: RKS 908.2
Datenstand: 20100327
                 Adresse 46: Komfortsystem  (8P0 959 433 )
20:02:26 Block 018: Alarmhorn/Sounder (Alarmauslöser)
  1.0  1. Alarmauslöser Alarmhorn
  1.0  2. Alarmauslöser Alarmhorn
  1.0  3. Alarmauslöser Alarmhorn
  0.0  4. Alarmauslöser Alarmhorn
20:02:26 Block 019: Innenraumüberwachung (Alarmauslöser)
  2.0  1. Alarmauslöser Innenraumüberw.
  1.0  2. Alarmauslöser Innenraumüberw.
  2.0  3. Alarmauslöser Innenraumüberw.
  2.0  4. Alarmauslöser Innenraumüberw.
20:02:26 Block 020: Alarmquellen
  18  1. Alarmquelle
  18  2. Alarmquelle
  18  3. Alarmquelle
  0  4. Alarmquelle
And here is the complete error log:
Code:
Dienstag,14,September,2010,19:58:09:48582
Fahrzeugtyp: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 69 76
          77
Fahrzeug-Ident.-Nr.: WAUZZZ8P96A041648   Kilometerstand: 54720km
00-Lenkwinkelsensor -- Status: OK 0000
01-Motor -- Status: Fehler 0010
02-Getriebe -- Status: OK 0000
03-Bremsen -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: Fehler 0010
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: Fehler 0010
17-Kombiinstrument -- Status: OK 0000
19-CAN-Gateway -- Status: OK 0000
25-Wegfahrsperre -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Türelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: Fehler 0010
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: OK 0000
52-Türelektr. Beifahr. -- Status: OK 0000
55-Leuchtweitenreg. -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Anhänger -- Status: Fehler 0010
76-Einparkhilfe -- Status: Fehler 0010
77-Telefon -- Status: OK 0000
Adresse 01: Motor        Labeldatei: RKS\06F-907-115-AXX.lbl
   Teilenummer SW: 8P0 907 115 A    HW: 8P0 907 115 A
   Bauteil: 2.0l R4/4V TFSI G00 0150
   Revision: --H01---    Seriennummer: AUX7Z0E6FNM07C
   Codierung: 010300031C070160
   Betriebsnr.: WSC 06314 000 00000
1 Fehler gefunden:
001089 - Tankentlüftungssystem: Durchsatz fehlerhaft
               P0441 - 001 - oberer Grenzwert überschritten
             Umgebungsbedingungen:
                    Fehlerstatus: 01100001
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 2
                    Kilometerstand: 54296 km
                    Zeitangabe: 0
                    Datum: 2010.08.26
                    Zeit: 09:18:18
                    Drehzahl: 836 /min
                    Last: 21.2 %
                    Geschwindigkeit: 0.0 km/h
                    Temperatur: 88.0°C
                    Temperatur: 27.0°C
                    Druck: 990.0 mbar
                    Spannung: 14.224 V
Readiness: 0000 0000
Adresse 02: Getriebe        Labeldatei: RKS\02E-300-0xx.lbl
   Teilenummer SW: 02E 300 042 Q    HW: 02E 927 770 AE
   Bauteil: GSG DSG         070 0928
   Revision: 04507000    Seriennummer: 00000507060459
   Codierung: 0000020
Kein(e) Fehler gefunden.
Adresse 03: Bremsen        Labeldatei: RKS\1K0-614-517-MK60-F.lbl
   Teilenummer SW: 1K0 614 517 R    HW: 1K0 614 517 R
   Bauteil: ESP FRONT MK60-AT   0103
   Revision: 00T12001
   Codierung: 0053890
   Betriebsnr.: WSC 60992 150 83573
Adresse 08: Klima/Heizung        Labeldatei: RKS\8P0-820-043.lbl
   Teilenummer SW: 8P0 820 043 L    HW: 8P0 820 043 L
   Bauteil: KlimavollautomatH16 0200
   Revision: 019157      Seriennummer: 8P0820043L
Adresse 09: Bordnetz        Labeldatei: RKS\8P0-907-279-23-H.lbl
   Teilenummer SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Bauteil: Bordnetz-SG     H36 1201
   Revision: 00H36000    Seriennummer: 00000002084364
   Codierung: E58E5F068414101400000000000000000008FE175C0200
   Betriebsnr.: WSC 06314 000 08192
   Teilenummer: 8P1 955 119 B
   Bauteil: Wischer AU350   H01 0130
   Codierung: 00062736
   Teilenummer: 4E0 910 557
   Bauteil: REGENLICHTSENSORH10 0050
   Codierung: 00150573
1 Fehler gefunden:
01299 - Diagnose-Interface für Datenbus (J533)
            004 - kein Signal/Kommunikation - Sporadisch
                    Fehlerstatus: 00100100
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 216
                    Verlernzähler: 160
                    Zeitangabe: 0
                        aus
                    Spannung: 12.00 V
                        aus
                        ein
                        aus
                        aus
                        aus
Adresse 15: Airbag        Labeldatei: RKS\8P0-959-655-94.lbl
   Teilenummer SW: 8P0 959 655 H    HW: 8P0 959 655 H
   Bauteil:    Airbag 9.41  H11 3520
   Revision: 91H1135    Seriennummer: 0037W000DZKO
   Codierung: 0070612
Adresse 16: Lenkrad        Labeldatei: RKS\8P0-953-549.lbl
   Teilenummer SW: 8P0 953 549 E    HW: 8P0 953 549 E
   Bauteil: Lenksäulenmodul H34 0070
   Codierung: 0011142
   Teilenummer: XXXXXXXXXXX
   Bauteil: Lenkradmodul    H03 0080
2 Fehler gefunden:
01317 - Steuergerät im Schalttafeleinsatz (J285)
Adresse 17: Kombiinstrument        Labeldatei: RKS\8P0-920-xxx-17-MY7.lbl
   Teilenummer SW: 8P0 920 930 T    HW: 8P0 920 930 T
   Bauteil: KOMBIINSTR. VDO H80 0460
   Revision: D03         Seriennummer: 2246ED03003366
   Codierung: 0000013
   Betriebsnr.: WSC 79766 146 89450
Adresse 19: CAN-Gateway        Labeldatei: RKS\1K0-907-530.lbl
   Teilenummer SW: 1K0 907 530 F    HW: 1K0 907 951
   Bauteil: Gateway         H10 0120
   Revision:   H10       Seriennummer: 28001057138141
   Codierung: 7F0F47CA070100
   Betriebsnr.: WSC 75230 146 56555
Adresse 25: Wegfahrsperre        Labeldatei: RKS\1K0-920-xxx-25.lbl
   Revision: D03         Seriennummer: AUX7Z0E6FNM07C
Adresse 37: Navigation        Labeldatei: RKS\8E0-035-192-RNSE.lbl
   Teilenummer SW: 8P0 035 192 A    HW: 8P0 035 192 A
   Bauteil: RNS-E HIGH EU   H70 0650
   Revision:      01S    Seriennummer: AUZBZ7E0903364
   Codierung: 0205711
Adresse 42: Türelektr. Fahrer        Labeldatei: RKS\8P0-959-801-MAX1.lbl
   Teilenummer: 8P0 959 801 F
   Bauteil: Tuersteuerger.  H10 0040
   Codierung: 0000120
Adresse 44: Lenkhilfe        Labeldatei: RKS\1Kx-909-14x.lbl
   Teilenummer: 1K0 909 144 J
   Bauteil: EPS_ZFLS Kl. 000    3001
   Revision: 00H17000
1 Fehler gefunden:
00750 - Fehlerlampe
            013 - bitte Fehlerspeicher auslesen - Sporadisch
                    Fehlerstatus: 00101101
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 40
                    Zeitangabe: 0
                    Spannung: 11.88 V
                        DD
                    Temperatur: 22.0°C
                    Drehzahl: 0 /min
                    Anzahl: 0
Adresse 46: Komfortsystem        Labeldatei: RKS\8P0-959-433.lbl
   Teilenummer: 8P0 959 433
   Bauteil:    KSG          H03 0040
   Codierung: 1880004C7F280D0DC88AC61300
   Teilenummer: 1K8 951 605
   Bauteil: LIN BACKUP HORN H09 9002
   Teilenummer: 1K0 907 719 C
   Bauteil: Neigungssensor  005 0003
   Teilenummer: 8P0 951 177
   Bauteil: Innenraumueberw.H03 0020
1 Fehler gefunden:
Adresse 47: Soundsystem        Labeldatei: RKS\8Px-035-382.lbl
   Teilenummer SW: 8P3 035 382     HW: 8P3 035 382
   Bauteil: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Seriennummer: 10000001265970
Adresse 52: Türelektr. Beifahr.        Labeldatei: RKS\8P0-959-802-MAX1.lbl
   Teilenummer: 8P0 959 802 F
   Codierung: 0000120
Adresse 55: Leuchtweitenreg.        Labeldatei: RKS\8P0-907-357.lbl
   Teilenummer: 8P0 907 357 C
   Bauteil: Dynamische LWR  H01 0010
   Revision: 00000000    Seriennummer:
   Codierung: 0000001
Adresse 56: Radio        Labeldatei: RKS\8E0-035-192-RNSE.lbl
   Codierung: 0205711
Adresse 69: Anhänger        Labeldatei: RKS\8P0-907-383.lbl
   Teilenummer SW: 8P0 907 383     HW: 8P0 907 383
   Bauteil: ANHAENGERELEKTR H01 0010
   Codierung: 0000001
1 Fehler gefunden:
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 15
                    Verlernzähler: 160
                    Kilometerstand: 53104 km
                    Zeitangabe: 0
                    Datum: 2010.06.17
                    Zeit: 19:18:00
Adresse 76: Einparkhilfe        Labeldatei: RKS\8P0-919-283.lbl
   Teilenummer SW: 8P0 919 283 A    HW: 8P0 919 283 A
   Bauteil: Parkhilfe 4-Kan H09 0010
   Revision: 00H09000    Seriennummer: 00067824820519
   Codierung: 0011003
2 Fehler gefunden:
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 254
                    Verlernzähler: 160
                    Kilometerstand: 0 km
                    Zeitangabe: 0
01517 - Steuergerät für Anhängererkennung (J345)
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 40
                    Zeitangabe: 0
Adresse 77: Telefon        Labeldatei: RKS\8P0-862-335.lbl
   Teilenummer SW: 8P0 862 335 C    HW: 8P0 862 335 C
   Bauteil: FSE_255x BT     H18 0160
   Revision: 00000001    Seriennummer: 00000000277191
   Codierung: 0010311
Ende   --------------------------------------------------------------------
Thank you very much.
Translated on 30-08-2026, 9:43.
Post26-09-2010, 16:11    Subject: A3 8P Alarm: Gateway Issues & Error Solutions Quote
You have the error
01299 - Diagnostic interface for data bus (J533)
multiple times; the J533 is the CAN gateway (address 19).
-> There's either a wiring fault, or, which I find more likely, a fault in module J533. Because if the problem were with the CAN bus wiring, module J533 would also have errors.
Unless it occasionally loses power itself, in which case it can't log any errors, but it can still detect errors in other ECUs that are producing them.
VG, Rainer.
Translated on 30-08-2026, 9:46.
NoSleep
Post26-09-2010, 16:32    Subject: A3 8P Alarm: Gateway Issues & Error Solutions Quote
Thank you.
Are there any known failure points or common locations where this type of cable breakage is likely to occur?
Can software problems be ruled out?
Could the engine control unit (ECU) also be defective, requiring a complete replacement?
Greetings,
Robert.
Translated on 30-08-2026, 9:47.
Post03-10-2010, 19:06    Subject: A3 8P Alarm: Gateway Issues & Error Solutions Quote
No.
Yes...
As I said, the easiest thing to do first would be to measure the cables.
Translated on 30-08-2026, 9:48.
No new posts VW Touran Document, Alarm Triggered by Backup Horn Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Convertible Alarm: 2001 Doku & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Error 01044 on CAN Gateway: How to fix it On-Board Diagnostics (OBD)
No new posts Disable 4Motion control module in the CAN gateway On-Board Diagnostics (OBD)
No new posts CAN Gateway A3 8PA: Incorrect Coding? On-Board Diagnostics (OBD)
No new posts Passat 3C: Gateway Replacement Guide On-Board Diagnostics (OBD)
