Difference 1Z to ALH
Gummimacher
Post18-11-2010, 19:17    Subject: Difference 1Z to ALH Quote
Yes, I have read the technical articles and also used the search function for "Difference 1Z ALH".
Can someone briefly explain the differences to the o.g. Show motor options?
I own a Golf 4 from 2000 (ALH) and now also an Audi 80 B4 (1Z) from 1994.
When accelerating gently with minimal load, I notice that the 1Z engine runs very rough in the 1000-1500 rpm range, while the ALH engine runs smoothly.
An bd. "The engines are equipped with a standard wastegate charger."
Thank you in advance!
Post18-11-2010, 19:25    Subject: Re: Difference between 1Z and ALH Quote
Gummimacher wrote:
On the boulevard. Standardmäßig ist ein Wastegate-Lader an den Motoren verbaut.
Post18-11-2010, 19:26    Subject: Re: Difference between 1Z and ALH Quote
Could you please repeat that??
The search function is really great:
/viewtopic.php?t=15409&highlight=alh+turbo
/viewtopic.php?t=16061&highlight=alh+1
Furthermore, the ALH must also be a solid block without any intermediate components.
Octavia_4x4
Post18-11-2010, 19:36    Subject: Difference 1Z to ALH Quote
However, the ALH has a VTG turbocharger, so please check it carefully.
Diesel_Rudi
Post20-11-2010, 23:49    Subject: Difference 1Z to ALH Quote
Yep. I can only agree with the previous speaker. ALH does not have a secondary drive for the oil pump and the vacuum pump, and it has a VTG (Variable Torque Converter) charger.
Octavia_4x4
Post21-11-2010, 9:48    Subject: Difference 1Z to ALH Quote
Furthermore, the 1Z has different nozzles, as the ALH already meets Euro 3 (= YELLOW)...
No new posts Volkswagen Golf 1.9 TDI 74 - 77 kW Diesel Engine Technology
No new posts V6 TDI: Differences between engine codes AFB and AKN Diesel Engine Technology
No new posts ALH vs. AFN Engine: Differences and Specs Diesel Engine Technology
No new posts 2.0 TDI CR: 143 PS vs. 120 PS - Comparison Diesel Engine Technology
