AGR Passat B6 140hp TDI
slg60
Post17-01-2011, 23:43    Subject: AGR Passat B6 140hp TDI Quote
My father-in-law has driven 21,000 km (approximately 13,000 miles) in his Passat, model year 2010, and now the engine check light has come on. The error code indicates a problem with the exhaust gas recirculation valve. VW has now ordered the AGR valve and, upon installation, noticed that all the pipes are heavily carbonized. They are now replacing the entire AGR system and installing a motor control unit update (VW's decision).
My question is: How can something like this happen in a car that's only 1.5 years old and has such low mileage? Could there be long-term damage to the engine? In theory, the carbon deposits could also form in the combustion chamber and potentially affect the valves and pistons. What do you think about that?
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post18-01-2011, 0:13    Subject: AGR Passat B6 140hp TDI Quote
Hello, it's possible that the operating profile is mostly within the active range of the AGR (Abgastuchreinigung - exhaust gas recirculation) system: low load, low temperature, and a lot of water vapor?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Doku Passat MKB AVB, Kraftstoffverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2.0 TDI 103kw(140PS) ruckelt. On-Board Diagnostics (OBD)
No new posts Limitation Maximum Speed Passat 3C 140PS TDI DPF Diesel Engine Technology
No new posts Ölverbrauch 2.0 TDI PD 140PS (BKD) Diesel Engine Technology
No new posts Engine knocking, 140hp 2.0 TDI with DPF (BMM) Diesel Engine Technology
