Error code: 001618 on T5 1.9 TDI, engine code: BRS
Post23-12-2010, 15:52    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Hello.
I've got a T5 here with a BRS engine that's broken down. If you turn it on for 5 seconds, it restarts, but then:
- DPF light on (but no longer on after replacing the catalytic converter).
- Turn on the MIL lamp.
- The filament is blinking.
- red oil lamp is flashing (but the main control unit indicates it's okay, seemingly intentional?).
- Turn on the ESP lamp.
- The tachometer is not working.
- The engine idles roughly.
Regarding the DPF light: The differential pressure sensor was faulty, so I replaced it, and now the light is off.
Does anyone have any idea what the error message actually means?
Code:
Adresse 01: Motorelektronik       Labeldatei: DRV\038-906-016-BRS.lbl
Steuergerät-Teilenummer: 038 906 016 T    HW: 038 906 016 T
Bauteil und/oder Version: R4 1,9L EDC  000SG  9711
Codierung: 0000031
Betriebsnummer: WSC 35110 377 00158
VCID: 2545C7119593
1 Fehler gefunden:
001618 - Geberreferenzspannung -B-: zu klein
               P0652 - 000 -  -  - Warnleuchte EIN
             Umgebungsbedingungen:
                    Fehlerstatus: 11100000
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 91085 km
                    Zeitangabe: 0
                    Drehzahl: 903 /min
                    Geschwindigkeit: 0.0 km/h
                    Binärwert: 00100000
                    Binärwert: 00000000
                    Binärwert: 00100000
                    Binärwert: 00100000
                    Binärwert: 00000000
Readiness: 0 0 0 0 1
Thank you in advance for any tips you may have.
Translated on 04-07-2026, 10:23.
Post23-12-2010, 17:04    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Does a donor short-circuit the +5V line? Are the voltage regulators in the engine control unit (ECU) okay?
Translated on 04-07-2026, 10:24.
Post23-12-2010, 17:28    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Best regards, Rainer
Hi Rainer,
I just found this:
Lo and behold, at idle with the engine running, the boost pressure is 2320 millibars. Disconnecting the sensor will not achieve anything other than triggering a fault code related to the intake air temperature sensor.
Measured the supply voltage:
Temperature sensor: 4.96V
Pressure sensor: 4.60V http://wiki.ross-tech.com/wiki/index.php/17036/P0652/001618
Okay, so it's time to check the cables now.
Translated on 04-07-2026, 10:25.
vagtuning
Post23-12-2010, 20:52    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
The G28 (crankshaft position sensor), the MAF sensor (mass airflow sensor), and the AGR valve (exhaust gas recirculation valve) should still be connected to the Ref.B unit.
You can still disconnect it beforehand.
Ref. A corresponds to G40, G79, and V157.
I can't remember the others.
If you don't want to deal with patching and it's the main cable for the G31...1KD 971 658.
I think that might also work for the bus...
Translated on 04-07-2026, 10:27.
Post24-12-2010, 10:31    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
vagtuning wrote:
The G28, the mass airflow sensor (LMM), and the EGR valve must still be connected to Ref.B.
You can detach that beforehand, if you want.
Remove the AGR valve, remove the MAF sensor, remove the lambda sensor, remove the G28 sensor, and then the error code should disappear.
If I plug everything in except for the EGR valve, the error doesn't appear. With the EGR valve installed, it's ready.
Without the valve, it starts immediately, and the tachometer also works again. icon_biggrin.gif
A new valve will be ordered on Monday, and then everything should be fine.
Translated on 04-07-2026, 10:29.
vagtuning
Post24-12-2010, 13:18    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Well, at least there's something positive to say about Christmas...
Happy holidays.
Translated on 04-07-2026, 10:30.
Post27-12-2010, 18:03    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Final Report:
T5 is already back on the road.
After replacing the EGR valve, all the error codes could be cleared, and all the warning lights are now off.
The actual fault in the valve was quickly identified. The valve stem, which connects to the electronics, was leaking. The electronics were completely covered in a mixture of oil and dirt. After cleaning the electronics, the old valve no longer showed any errors either. The valve was already so leaky that the entire back of the engine, all the way to the oil pan, was covered in oil. Therefore, simply cleaning and reusing the old valve would likely not have provided a long-lasting solution.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post27-12-2010, 20:58    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Okay, a question: Was the oil leak on the rear side of the engine, under the turbo and to the right of the driveshaft, smeared all the way down to the oil pan?
I actually had one where VW told me, based on the image, that the oil supply to the turbo was the culprit. "That would require removing the turbocharger, DPF, etc."
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 04-07-2026, 10:32.
Post29-12-2010, 0:25    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Hi Klausi,
"No, it all came from the valve. What you're talking about probably refers to the 5-cylinder engines that no longer have oil lines to the turbo, but instead have holes in the cylinder head and manifold, right? The BRS is just a normal, old 1.9 PD engine, but with a DPF and all the other stuff. If something was coming from the turbo, you would have seen it immediately." The turbo was definitely completely dry.
Translated on 04-07-2026, 10:33.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post29-12-2010, 9:33    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
Okay Michael, I've only read about the T5, who would buy a 1.9 liter engine for a T5? icon_rolleyes.gif
You're right, it's different for you. Thank you.
Translated on 04-07-2026, 10:34.
Post29-12-2010, 9:54    Subject: Error code: 001618 on T5 1.9 TDI, engine code: BRS Quote
teileklaus wrote:
"No, he has the AXC with even fewer horsepower; the BRS has at least 102 horsepower. But I have to admit, it doesn't drive that badly; I really expected it to be much slower. icon_wink.gif"
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlercode 17664 beim AUY TDI 85KW Bj. 3/00 Diesel Engine Technology
No new posts Toledo TDI AFN: Error Code 01237 Troubleshooting On-Board Diagnostics (OBD)
No new posts Error code on 1.9 TDI AFN engine - Strange error! On-Board Diagnostics (OBD)
No new posts Error code 00778 - Steering angle sensor (G85) on the Pol... Electrical Systems, Vehicle Electronics, Multimedia
