Squealing at low RPM
Post18-03-2003, 8:47    Subject: Squealing at low RPM Quote
Hi.
I often drive around the city at very low RPMs; the TDI engine has enough power to handle it.
Recently, I noticed the following (G3 Variant TDI 1Z, manufactured in 1996, 135,000 km):
When it's running at approximately 1000 RPM and under load, there's a squeaking sound coming from the engine compartment that is synchronized with the motor's vibrations (which I can hear as the driver through open windows).
The timing belt tensioner is new. According to the sticker on the rear swingarm, the timing belt was replaced at 91,000 km.
Are there any typical "little birds" that cause this chirping?
Greetings.
Martin.
Translated on 19-07-2026, 12:21.
Michael II
Post18-03-2003, 8:52    Subject: Squealing at low RPM Quote
Have you checked the engine mounts?
Tschüss
Michael II
Translated on 19-07-2026, 12:22.
Post18-03-2003, 9:06    Subject: Re: Squealing/Whining noise at low RPM Quote
How about the spooling mechanism for this reel? Mine has been defective several times.
Translated on 19-07-2026, 12:23.
Post19-03-2003, 16:09    Subject: Squealing at low RPM Quote
- How can I check the engine mounts?
The only thing I've noticed about it is the "popping" sound of the front hydraulic bearing when starting up quickly.
- The timing belt tensioner roller and its tensioner are new (sorry, I thought they were always replaced together).
Or maybe it's only the tensioner that is new (which it definitely is), and they put the old belt on again icon_evil.gif.
Translated on 19-07-2026, 12:24.
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AHF engine misfire at low RPM Upload
No new posts G4 AHF (110PS) Ruckeln bei niedriger Drehzahl On-Board Diagnostics (OBD)
No new posts Failure of climate control at low speed / ambient tempera... Transmission, Chassis, Body & Interior
No new posts Stalling at low RPM (Golf 3 TDi Variant) Diesel Engine Technology
