Transporter T4: Rear Door Lock Malfunction Repair (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post20-03-2003, 11:01    Subject: Transporter T4: Rear Door Lock Malfunction Repair Quote
In T4 vehicles with central locking, improper operation can sometimes cause the lock mechanism to become jammed.
Cause:
This happens when the lock actuator is held in the "pressed" position while the vehicle is locked, and at the same time, the vehicle is unlocked using the central locking system or remote control. In this situation, the angled actuator lever is forced past its limit stop and becomes jammed. The actuator then stops functioning.
Solution:
To open the rear door, press the activation lever in the opposite direction (towards the license plate) until you hear a click indicating that it has been released.
Tschüss
Michael II
Translated on 04-08-2026, 17:43.
Ratings - Transporter T4: Rear Door Lock Malfunction Repair
No new posts Transporter 7D Clutch Problems: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Documentary about Whistling Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Back door lock, Touran, left side, defective. Transmission, Chassis, Body & Interior
No new posts T6 Transporter, Noise Reduction Transmission, Chassis, Body & Interior
No new posts VW Transporter T4 and flashing oil pressure light Diesel Engine Technology
No new posts 2004er T5-Transporter 1.9 TDI: (War: Tuerenklappern). Transmission, Chassis, Body & Interior
