The serpentine belt is making noise when starting and stopping the engine.
Cause:
In some cases, the ribbed belt may slip when starting or stopping the engine, which can cause noise.
Solution:
For quality reasons, the material of the V-ribbed belt has been changed.
No. 074 145 933 AR = Base drive 1751 mm.
No. 074 260 849 AE = Climate Drive 2211 mm.
Warning: These V-ribbed belts can only be used for vehicles with chassis number 70 X.170 001 and later.
Tschüss
Michael II
Translated on 31-10-2026, 22:03.
