Transporter 7D: Documentary about Whistling Noises (Solution)
Michael II
Post20-03-2003, 11:06    Subject: Transporter 7D: Documentary about Whistling Noises Quote
As the vehicle's speed increases, a loud whistling noise occurs.
A noise is occurring in the area of the control panel. This affects vehicles with air conditioning.
Cause:
The whistling sound could be caused by a wrongly installed or kinked water drain hose on the blower housing.
Solution:
Check if rotating the water hose eliminates the noise. If this measure is unsuccessful, replace the water drain hose with part number: 7D0 820 124.
Tschüss
Michael II
Translated on 06-08-2026, 22:45.
Ratings - Transporter 7D: Documentary about Whistling Noises
No new posts Document A3 8L from 18/2000 onwards, whistling sounds fro... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 12/00: Whistling noises from ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Whistle Sounds: Types, Causes & How to Fix Transmission, Chassis, Body & Interior
No new posts Automatic Transmission Whining Noise? Diesel Engine Technology
No new posts T6 Transporter, Noise Reduction Transmission, Chassis, Body & Interior
No new posts VW Transporter T4 and flashing oil pressure light Diesel Engine Technology
