MSG Tuning: Boost Performance & Power
rainer1963
Post29-01-2011, 0:59    Subject: MSG Tuning: Boost Performance & Power Quote
I have a Golf 6 CR 1.6 TDI with 90 hp. The engine code is CAYB, which is technically identical to the CAYC engine with 105 hp according to the SSP (Service Information). The difference in power is supposedly only due to different software.
Can I convert it by replacing the MSG? And how do I get the WFS working?
Thank you.
Translated on 18-09-2026, 8:41.
vagtuning
Post29-01-2011, 14:48    Subject: MSG Tuning: Boost Performance & Power Quote
Certainly possible, but it will probably be easier.
A tuner simply plays the corresponding software, unlike replacing the main system board.
Perhaps Rainer will say something about the meaning/cost.
The warranty will be completely void in that case.
Translated on 18-09-2026, 8:42.
chli1976
Post29-01-2011, 20:22    Subject: MSG Tuning: Boost Performance & Power Quote
Doesn't it have a VDO Continental control unit? If so, tuning options are currently limited.
VCDS
rainer1963
Post29-01-2011, 22:21    Subject: MSG Tuning: Boost Performance & Power Quote
vagtuning wrote:
Possible, certainly, but it will probably be easier.
The warranty is then completely void.
Okay, here's the translation:
"Thank you. As far as I know, the tuners for the MKB CAYB engine play a different software map compared to the CAYC variant. This means 110-120 horsepower instead of 125-140 horsepower for the CAYC. Regardless of any subsequent tuning, an MSG (Engine Control Module) for upgrading to 105 horsepower is available for approximately EUR 300.00. If the cost of adapting the water pump and thermostat (WFS) remains reasonable, this represents a relatively "cheap" 15 horsepower increase. Furthermore, there's the option to gain an additional 15-20 horsepower on top of the original MSG."
Translated on 18-09-2026, 8:43.
mullemaus
Post31-01-2011, 0:14    Subject: MSG Tuning: Boost Performance & Power Quote
Doesn't it have a VDO Continental control unit installed? If so, the tuning options are currently limited.
Okay. icon_wink.gif There is no software solution on the market for these control units.
Translated on 18-09-2026, 8:44.
Ross-Tech-Support
Post31-01-2011, 11:48    Subject: MSG Tuning: Boost Performance & Power Quote
A swap due to different performance classes is not possible; in other words, even a new CAYC control unit cannot be simply connected to your existing WFS system.
Translated on 18-09-2026, 8:45.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts 10Cent Tuning Technical Articles
No new posts Hands-free noise in Audi A3 (1996-2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is tuning possible by replacing OEM messages? Gasoline Engine Technology
No new posts Software Tuning: Improve Performance Now! Diesel Engine Technology
No new posts LLK Tuning: More Power, Less Soot? Diesel Engine Technology
No new posts Automatic Transmission Tuning: Software Solutions Diesel Engine Technology
