Document LT 28, Transmission Noise (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post20-03-2003, 12:53    Subject: Document LT 28, Transmission Noise Quote
Noises from the engine when starting up
Metallic clacking sounds from the powertrain during acceleration in 1st and reverse gear.
Cause.
Due to manufacturing tolerances in the splined connection between the output shaft and the output flange, relative movements can occur, which can lead to noise.
Solution:
In the event of a persistent complaint, proceed as follows:
Remove the driveshaft and output flange.
Interlocking of the drive shaft/drive flange, clean (must be free of oil and grease).
Apply sealant D 185 400 A2 to the connection and reassemble the parts accordingly.
Until the adhesive has fully cured (approximately 3 hours), the bonded joint must not be subjected to any load.
Tschüss
Michael II
Ratings - Document LT 28, Transmission Noise
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission AFN: Gearbox-Axle Assembly Oil Cha... Diesel Engine Technology
No new posts 5-Gang Getriebe auf 6-Gang Getriebe erweitern beim G3 AHU Diesel Engine Technology
No new posts Getriebe Nm Diesel Engine Technology
No new posts TDI mit Getriebe vom TD? Diesel Engine Technology
