Hello Markus!
Before my A6, I also had a new Golf IV. In the spring, as it got warmer, both front doors started to creak when starting, braking, and driving over uneven surfaces. As far as I know, there are two possible causes for this. In my case, it was the door hinges, where the grease probably leaked out due to the heat. I also believe there were issues with the lock, which can also cause creaking. If I remember correctly, VW sometimes replaces this part free of charge under warranty?
DENNIS
Hello everyone!
Who can help me with this? I drive a Golf IV and I have a short, bright cracking sound in the passenger door when starting, braking, and going over bumps. I've already lubricated the bracket in the B-pillar, but without success.
Thanks, markus.
