How to Clear Bluetooth Module Memory
Go to page: 1, 2, 3  Next
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
stolley
Karma: +38 / -1   Thank you, like it!
Post05-10-2013, 20:30    Subject: How to Clear Bluetooth Module Memory Quote
Hello everyone!
I have a pre-wiring kit installed in my T5 for a hands-free phone system.
Therefore, I bought an adapter for the iPhone 5.
The connection with the car's system works perfectly, and consequently, so does the hands-free calling feature.
However, when I try to connect a second iPhone 5 (or an iPhone 4, or any other Bluetooth-enabled device) to the bus, it doesn't even appear in the list of available devices.
VW says I should try to delete the list of paired devices.
"Surely this should work with VCDS, right? Can anyone tell me how to do it? Which channel do I need to select, etc.?"
Thank you all!
Translated on 01-08-2026, 15:48.
Post06-10-2013, 12:14    Subject: How to Clear Bluetooth Module Memory Quote
Can someone tell me how to do this? Which channel I need to select, etc.?
Hmm, which file system is installed?
On a Golf 6 from 2011 with the premium hands-free system, for example, there is (as far as I recall) a function in the adjustment menus that is similar to "delete profiles" or "reset to factory settings."
Regarding the T5 -- ?
Otherwise, please post the error scan so we can see what components are installed.
Translated on 01-08-2026, 15:50.
Post07-10-2013, 14:44    Subject: How to Clear Bluetooth Module Memory Quote
Profiles can be deleted either through the menu (MFA) or via the diagnostics section.
The T5.2 uses standard PFSE (Pressure Feedback System Elements), and I once tested one with the part number 3C8 035 730 B.
However, this should not change anything about the "please Autoscan" request.
Translated on 01-08-2026, 15:52.
stolley
Post07-10-2013, 20:39    Subject: How to Clear Bluetooth Module Memory Quote
Hello everyone!
Thank you in advance for your answers!
Here is the VCDS excerpt:
Address 77: Phone (J738) Label file: None.
Part number SW: 7H0 035 730, HW: 7H0 035 730.
Component: Telephone 005 1411
Revision: 00005000 Serial Number: 20330620005755
Encoding: 000211
Operating number: WSC 02756 790 00000
VCID: E1CF122CFB28C310CE2
Translated on 01-08-2026, 15:53.
stolley
Post14-10-2013, 22:25    Subject: How to Clear Bluetooth Module Memory Quote
I started VCDS again and searched through the adaptation channels.
I came across channel number 10.
You can adjust the Bluetooth visibility there. It was set to "off."
However, even switching to "one" didn't improve the situation – or, in other words, the bus remains invisible via Bluetooth to any device other than the one that is already paired with it.
Does anyone have any other suggestions?
Here are the adaptation channels that I found.
Sunday, October 13, 2013, 7:02:20 PM: 25065
VCDS version: RKS 11.11.6
Data as of: 20130111.
Channel number adjustment: 001:
Saved: 10
Volume.
Phone.
0.0 (no unit)
N/A
Sunday, October 13, 2013, 7:02:46 PM: 25065
Channel number adjustment: 002:
Saved: 10
Microphone.
0.0 (no unit)
N/A
N/A
Sunday, October 13, 2013, 7:02:58 PM: 25065
Channel number adjustment: 003.
Saved: 0
Bluetooth.
00
00
N/A
Sunday, October 13, 2013, 7:03:21 PM: 0.25065
Channel number adjustment: 004:
Saved: 0
BT connection.
delete
from
N/A
Sunday, October 13, 2013, 7:03:34 PM: 0.25065
Channel number adjustment: 005:
Saved: 10
Mute.
1.00 second.
N/A
N/A
Sunday, October 13, 2013, 7:03:46 PM: 0.25065
Channel number adjustment: 006:
Saved: 0
hesitate
0.00 ms mittl. Injection time.
N/A
N/A
Sunday, October 13, 2013, 7:03:57 PM: 25065
Channel number adjustment: 007.
Saved: 262
Language:
262.0 (no unit)
N/A
N/A
Sunday, October 13, 2013, 7:04:15 PM: 25065
Channel number adjustment: 008.
Saved: 135
DSP status.
one
N/A
N/A
Sunday, October 13, 2013, 7:04:27 PM: 25065
Channel number adjustment: 009.
Saved: 10
Media
Playback.
Volume.
0.0 (no unit)
Sunday, October 13, 2013, 7:04:47 PM: 0.25065
Adjusting channel number: 011:
Saved: 10
Confirmation tone.
4.0 (no unit)
N/A
N/A
And here is the extended identification of the component:
Sunday, October 13, 2013, 7:07:00 PM: 25065
Address 77: Phone number.
Control unit part number: 7H0 035 730.
Component and/or version: Telephone 005 1411.
Encoding: 000211
Company number: WSC 02756.
VCID: E1CF122CFB28C310CF5
Enhanced identification.
Serial number: 20330620005755
Identification: NOK-BO1
Revision: 00005000
Date: 2007-12-07
Manufacturer part number: 0000
Proof number: 0575
Flash status.
Programming attempts (application): 0.
Successful attempts (applications): 0.
Programming attempts (data): 0.
Successful attempts (data): 0.
Programming status: 00000000
Flash Date: --.----
Flash Tool Number: 00000 000 00000
Flash Tool Number (Data): 00000 000 00000
Miscellaneous.
Hardware number: 7H0 035 730.
System abbreviation: J738
Features/PR code: 0000000000000000
VCDS Info:
Label file: NONE.
Translated on 01-08-2026, 16:05.
stolley
Post19-10-2013, 20:42    Subject: How to Clear Bluetooth Module Memory Quote
Does anyone have a suggestion?
Translated on 01-08-2026, 16:17.
Post20-10-2013, 10:53    Subject: How to Clear Bluetooth Module Memory Quote
Adaptation channel 0 often clears the learned values in many control units; whether this helps depends on the specific situation and may require experimentation.
Translated on 01-08-2026, 16:18.
stolley
Post24-11-2013, 20:55    Subject: How to Clear Bluetooth Module Memory Quote
dieselschrauber wrote:
Adaptation channel 0 deletes the learned values in many control units; whether this helps -> try it out.
I just tried that out.
According to adaptation channel 0, storing data actually resets the learning values.
Unfortunately, VCDS crashes during this process.
Then I found another setting option: "Bluetooth visibility."
It was turned off.
Unfortunately, enabling the visibility option didn't help either.
Does anyone else have any experience with this?
Translated on 01-08-2026, 16:19.
Post25-11-2013, 18:12    Subject: How to Clear Bluetooth Module Memory Quote
I don't know if this will help you, but in any case, I would definitely install the most current version first when encountering such problems (VCDS crashes).
Translated on 01-08-2026, 16:20.
stolley
Post26-11-2013, 7:28    Subject: How to Clear Bluetooth Module Memory Quote
Roger wrote:
I don't know if this will help you, but in any case, I would definitely install the most up-to-date version first when encountering such problems (VCDS crashes).
Hi!
It is installed.
Perhaps I can reduce the CPU load in the settings?
Surely there's an option like that, right?
Translated on 01-08-2026, 16:21.
Post26-11-2013, 7:43    Subject: How to Clear Bluetooth Module Memory Quote
Your excerpts still showed the date 11/11/6...
I don't think focusing on CPU load will achieve anything.
stolley
Post26-11-2013, 15:42    Subject: How to Clear Bluetooth Module Memory Quote
CPU load won't achieve anything, in my opinion.
Um, correct!
Translated on 01-08-2026, 16:22.
stolley
Post04-12-2013, 7:13    Subject: How to Clear Bluetooth Module Memory Quote
Does anyone have any ideas?!
Translated on 01-08-2026, 16:23.
Post04-12-2013, 16:58    Subject: How to Clear Bluetooth Module Memory Quote
Okay, what happens to adaptation channel 0 in VCDS version 12.12.0 now?
Okay, hier ist die Übersetzung des deutschen Texts ins Englische:
"Please also provide the current Autoscan results."
stolley
Post08-12-2013, 19:45    Subject: How to Clear Bluetooth Module Memory Quote
Yes, what happens now with adaptation channel 0 in VCDS version 12.12.0?
Well, as I mentioned before: VCDS unfortunately crashes (no feedback). I just tried it again. I even specifically enabled the options to reduce the CPU load!
Please also post the current Autoscan.
And here's the latest car review:
Sunday, December 8, 2013, 7:16:22 PM: 25065
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: 12.12.0.0
Data as of: 20131116.
Vehicle Identification Number (VIN): WV2ZZZ7HZ8Hxxxxxxx
License plate: A-xx xxxx
Mileage: 128940 km. Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: 7H (7H - Bus (A-VA 1001)).
Scan: 01 02 03 08 09 15 17 18 19 37 45 46 56 77
Vehicle Identification Number (VIN): WV2ZZZ7HZ8H109783
Mileage: 128,940 km
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Unit (ECU)
Label file: RKS\070-906-016-BPC.clb
Part number SW: 070 906 016 DR, HW: 070 906 016 DR.
Part: R5 2.5L EDC G000AG 1584
Revision: --H06--- Serial Number: VWZ7Z0G6131852
Encoding: 0001075
Operating number: WSC 30696 264 83473
VCID: 63C39824A1345106E91-515A
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: RKS\09G-927-750.lbl
Part number SW: 09K 927 750 L, Hardware part number: 09K 927 750 L.
Component: AQ 250 6F 1045
Revision: 00H67000 Serial Number:
Encoding: 0000072
VCID: 3E7509506A165CEEA6F-515A
Address 03: Brake Electronics
Label file: RKS\7H0-907-37x-ESP.lbl
Part number SW: 7H0 907 379 R, HW: 7H0 907 379 R.
Component: ESP MK25E1 0104
Revision: 00H31001
Coding: 0000555
VCID: 44817BB804FA363EF0B-515A
Address 08: Climate Control/Heating Unit. Label file: RKS\7Hx-907-040.lbl
Part number: 7H5 907 040 D
Component: CLIMAtronic T5 4221
Encoding: 0011040
Operating number: WSC 02757 790 00000
VCID: 2C5133188C6ADE7E18B-515A
Subsystem 1 - Part number: 7H5 907 049 D
Part number: Display_2_ClimaT5 X 0307
"One error found:"
01592 - Air quality sensor (G238)
010 - Short circuit after positive terminal.
Address 09: Central Electronics
Label file: RKS\7H0-937-049.lbl
Part number: 7H0 937 049 AE.
Component: POWER SUPPLY UNIT SGVER 1.0 2101
Encoding: 0000359
VCID: 75E7D67C1FA0DFB6B75-513C
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 F
Part number: 11 AIRBAG VW61 0R 0004.
Encoding: 12593
VCID: 275BCC34C58CFD26F59-513C
Address 17: Control panel module
Label file: RKS\7Hx-920-xxx-17.lbl
Part number: 7H5 920 872 L
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V02
Encoding: 05113
Operating number: WSC 71692
VCID: 3C7103582C0A4EFE88B-515A
WV2ZZZ7HZ8H109783 VWZ7Z0G6131852
Address 18: Auxiliary heater
Label file: RKS\7H0-819-008.lbl
Part number: 7H0 815 071 F
Component: Auxiliary heater 0209.
Operating Number: WSC 00000 000 00000
VCID: 2B5330048964D946111-513C
Address 19: Diagnostic interface
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway <-> CAN bus 0001.
Encoding: 00006
VCID: F0E96768B0C27A9EE43-515A
Address 37: Navigation
Label file: RKS\7L6-919-887-DVD.lbl
Part number: 7H0 919 887 B
Component: Navigation 0030
Encoding: 0000101
VCID: 3B730044790449C6811-513C
Address 45: Interior monitoring.
Label file: RKS\7Hx-951-171.lbl
Part number: 7H5 951 171 C
Component: Interior monitoring system. 2917.
Coding: 0000012
VCID: 2F6B2414BD7CA5663D9-51B2
Subsystem 1 - Part number: 7H5 951 178.
Component: Interior monitoring system. 1607
Address 46: Comfort System
Label file: RKS\7H0-959-433.lbl
Part number: 7H0 959 433 B
Component: C11 Comfort Device 0004
Coding: 00031
VCID: 326D2D60FE4E888E527-4B18
Address 56: Radio
Label file: RKS\7L6-035-186-DVD.lbl
Part number: 7L6 035 186 D
Component: Radio 0030
Encoding: 0016410
VCID: 34612B78545A86BE40B-513C
Label file: None.
Encoding: 000211
VCID: E1CF122CFB28C3167BD-513C
"End"
Translated on 01-08-2026, 16:43.
Post08-12-2013, 20:01    Subject: How to Clear Bluetooth Module Memory Quote
Okay, thank you!
I also specifically enabled the options to reduce the CPU load!
It is usually not necessary.
What is your computer configuration? Do we understand "crashing" in the same way, meaning that the application terminates and needs to be restarted?
Translated on 01-08-2026, 17:10.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.6 TDI AGR module cannot be programmed Diesel Engine Technology
No new posts Module Codes Online: Find Them Here! On-Board Diagnostics (OBD)
No new posts Bluetooth Car Kit for VW: Hands-Free Upgrade Transmission, Chassis, Body & Interior
No new posts Car Radio with Bluetooth: Reliable & Affordable Electrical Systems, Vehicle Electronics, Multimedia
