mkersch Guest
11-04-2011, 19:27 Subject: Heating element flashes: Troubleshooting guide |
Hello forum members,
I drive a Sharan TDI with 90 horsepower (AHU engine), manufactured in 1998, with a mileage of 277,000 kilometers.
Yesterday, the engine stalled several times.
'The heating element indicator light is flashing. After a while, for example, 5 minutes, the motor stops.'
After stopping the engine for about 1 minute, I was able to drive a few more kilometers (the heating element indicator was flashing).
Today, I replaced the diesel filter and checked relay 109, including inspecting the solder joints.
resoldered.
Error description: ==> After starting the car, the heating element symbol starts blinking after 20 seconds.
What could be the cause of this error?
mkersch
Translated on 28-08-2026, 9:24.
11-04-2011, 19:32 Subject: Heating element flashes: Troubleshooting guide |
Read the error memory! If it's blinking, there's a reason, and it's described in there.  MfG. Michael
Translated on 28-08-2026, 9:26.
Profile PM Garage |
mkersch Guest
21-04-2011, 20:18 Subject: Heating element flashes: Troubleshooting guide |
I read the control unit of my Sharan.
It displayed a 'software error.' I reset this error. After that, it started blinking.
The heating coil is gone.
Today, this error occurred again: the heating element is blinking again.
The car would intermittently stall. After a short pause, it would start running again.
What could be the cause of the error?
mkersch
Translated on 28-08-2026, 9:27.
Deus Violentia Schrauber
21-04-2011, 20:21 Subject: Heating element flashes: Troubleshooting guide |
Okay, here's the translation:
"Again: please provide the exact error code!" BKD GRF
AHF EBF
mkersch Guest
22-04-2011, 8:44 Subject: Heating element flashes: Troubleshooting guide |
The following error message is displayed in the control unit:
VCDS-Lite Version: Release 1.1
Friday, April 22, 2011, 09:22:13.
Control Module Part Number: 028 906 021 GS
Component and/or Version: 1.9L R4 EDC 00SG 1904
Software Coding: 00002
Workshop Code: WSC 00020
VCID: 66BF359B1169
3 Faults Found:
65535 - Internal Control Module Memory Error.
35-10 - - - Intermittent
00575 - Shareware version. To decode all DTCs.
17-10 - Please Register/Activate - Intermittent
00513 - Shareware version. To decode all DTCs.
27-10 - Please Register/Activate - Intermittent.
What could be the cause?
mkersch
Translated on 28-08-2026, 9:29.
fantomas Blaumann
22-04-2011, 9:20 Subject: Heating element flashes: Troubleshooting guide |
The problem is likely due to error code 00513. The cause could be a faulty sensor or a broken cable. Also, pay attention to the tachometer when the error occurs.
Translated on 28-08-2026, 9:31.
servusssss Blaumann
Joined: 11/14/2006 Posts: 159 Karma: +12 / -0 Location: Vlbg
