LED auxiliary lights as "marker lights"
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1076 / -0   Thank you, like it!
Post23-09-2011, 21:45    Subject: LED auxiliary lights as "marker lights" Quote
Here's the situation: LED auxiliary lights are being mounted on the front bumper of a passenger car (i.e., a multi-lane vehicle, not a truck). These lights look like LED daytime running lights, but they do not have the ECE R87 approval marking. The lights in question do not have an "RL" approval but only an "A" approval. The color of their light is white.
In conclusion, this means that these lights should be classified as boundary lights, or, in colloquial terms, position lights. Consequently, according to § 51 of the German Road Traffic Licensing Regulations (StVZO), a total of up to four of these lights are permitted – in addition to the "parking lights" already integrated into the headlights, meaning an extra pair. The publication "Lighting Equipment on Motor Vehicles and Their Trailers" also mentions the dimensions that must be observed, as does the StVZO (e.g. The minimum height is 350 mm, the maximum is 400 mm, measured from the outer edges of the vehicles, and the minimum distance between them is 600 mm. These requirements were also met in the specific case.
I installed the lights according to their dimensions, neatly routed the cables, and connected them to the parking light circuit. This means they turn on with the parking lights and continue to illuminate when the low beam and/or high beam headlights are in use. The lights are designed to be glare-free. While the use of these lights in conjunction with the parking light during driving is not permitted (§ 17 of the Road Traffic Regulations), there is no requirement that this function be technically disabled.
Did I interpret that correctly?
Translated on 04-07-2026, 10:36.
Post24-09-2011, 10:01    Subject: LED auxiliary lights as "marker lights" Quote
...no idea...
...but why???
Translated on 04-07-2026, 10:38.
Karma: +784 / -0   Thank you, like it!
Post24-09-2011, 10:37    Subject: LED auxiliary lights as "marker lights" Quote
Translated on 04-07-2026, 10:39.
Post24-09-2011, 11:36    Subject: LED auxiliary lights as "marker lights" Quote
He might not want to, but it's designed in a way that it can't be used as daytime running lights. icon_twisted.gif
I just wanted to check if everything was installed and connected correctly.
Post25-09-2011, 19:42    Subject: LED auxiliary lights as "marker lights" Quote
Resolution:
 LED Leuchten
 File size:  31.75 KB
 Viewed:  1413 times
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Praxistest "Rain Shield" von No Touch General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Zu dumm zum Fahren ... oder: "Schöne" neue Welt Diesel Engine Technology
No new posts Euro 4 requirement from 2005 is not so "absolute"? Diesel Engine Technology
No new posts Austausch des RNS315 gegen neues "Discover Media" Electrical Systems, Vehicle Electronics, Multimedia
