Mercedes LMM to VW: Conversion Guide
C.F.
Post13-03-2003, 22:53    Subject: Mercedes LMM to VW: Conversion Guide Quote
Hi.
I just read a topic in the Passat 3B forum. That would be amazing: installing a mass airflow sensor (MAF sensor) from a Mercedes-Benz for 70 euros in the Passat. Visually, the parts are completely identical; you would just need to find out which Mercedes MAF sensor is closest to the VW part in terms of its measurement values. icon_wink.gif
Translated on 23-10-2026, 4:19.
Rudi
Post13-03-2003, 23:20    Subject: Mercedes LMM to VW: Conversion Guide Quote
Hello Claus,
It wouldn't surprise me. Mercedes-Benz already has a reputation for making money with its cars and selling spare parts at cost.
Most likely, the parts also come from Pierburg and even have the same connector configuration (at least if you can trust a post on the Passat forum).
Observe the situation for a while longer. Maybe eventually there will be a cross-reference between Benz and VAG.
Best regards, Rudi.
Translated on 23-10-2026, 4:20.
haehnlein
Post14-03-2003, 0:16    Subject: Mercedes LMM to VW: Conversion Guide Quote
....I will release one if that works icon_twisted.gif icon_twisted.gif.
____________
Kein Auto mehr!
Translated on 23-10-2026, 4:21.
rl2664
Post14-03-2003, 13:40    Subject: Mercedes LMM to VW: Conversion Guide Quote
Yes, yes, news like that spreads quickly...
It seems that's not correct. Part number 611 094 00 48 at DC is a mass airflow sensor (MAF) from Pierburg, not from Bosch. I just went to DC, and unfortunately, they didn't have one that I could have looked at.
Ronny.
Translated on 23-10-2026, 4:22.
Cord
Post14-03-2003, 20:17    Subject: Mercedes LMM to VW: Conversion Guide Quote
Some TDI models use Pierburg mass airflow sensors.
And with diesel engines, the readings from the mass airflow sensor are really irrelevant anyway.
Well, I think it will work out somehow.
The device has too much power and is smoking.
It has insufficient power.
or just some kind of emergency program.
joergs
Post14-03-2003, 20:33    Subject: Mercedes LMM to VW: Conversion Guide Quote
Some TDI models actually use a Pierburg mass airflow sensor.
Translated on 23-10-2026, 4:23.
rl2664
Post14-03-2003, 21:03    Subject: Mercedes LMM to VW: Conversion Guide Quote
The question is simply whether the oil cooler will physically fit in the space where the Bosch mass airflow sensor is located.
Ronny.
Translated on 23-10-2026, 4:24.
Manuel Thomas
Post17-03-2003, 17:23    Subject: Mercedes LMM to VW: Conversion Guide Quote
The problem has been solved.
It works! / It's working! / It's on!
Manuel.
Translated on 23-10-2026, 4:25.
Uwe
Post17-03-2003, 17:41    Subject: Mercedes LMM to VW: Conversion Guide Quote
And what about other parts, such as fuel injectors?
Uwe.
Post17-03-2003, 21:02    Subject: Mercedes LMM to VW: Conversion Guide Quote
Hello.
However, it seems that this only applies to the new generation of LMMs (linear motor modules), which are installed as inserts within the LMM tube and are fastened with screws.
Older Pierburg mass airflow sensors (like the one in my tractor icon_sad.gif) cannot be disassembled without destroying them. Does anyone know if it's possible to use "suitable, cheap DC parts" instead icon_question.gif?
Translated on 23-10-2026, 4:26.
Manuel Thomas
Post17-03-2003, 21:21    Subject: Mercedes LMM to VW: Conversion Guide Quote
I just noticed that too!
I'm going to visit a VW dealership tomorrow to see if they sell that 'holder tube' separately. It probably doesn't cost a fortune!
Manuel.
Translated on 23-10-2026, 4:27.
joergs
Post03-04-2003, 17:19    Subject: Mercedes LMM to VW: Conversion Guide Quote
Okay, according to my research, this Daimler part is also used in the AWX machine, and I believe it's also used in the other PD models.
In my AWX, the original part number is F 00c 2G2 027. And that's the exact part that users on the Passat3b forum have installed on various other MKBs. When I have more time, I'll go to DV and get one of those, and then I'll test it! icon_biggrin.gif
No new posts Mercedes Vito 10c: Parts for 1997/98 Models Diesel Engine Technology
No new posts Mercedes vs. Physics: The Ultimate Showdown Transmission, Chassis, Body & Interior
No new posts Mercedes OM 601.940 - Revision? Diesel Engine Technology
No new posts LMM Bosch Mercedes Values Diesel Engine Technology
