Air Suspension Failure: Allroad Problems (Solution)
Driver123
Post17-10-2011, 21:23    Subject: Air Suspension Failure: Allroad Problems Quote
Hello, I'm having the following problem with my Allroad from 2003, 120kw, engine code BCZ.
Always stays in the lowest position - The compressor starts running when I press to lift, but nothing happens - There is pressure, about 6 bar.
I have a second, fully functional Allroad available, and I'm using VCDS to compare the diagnostic data. The only difference I've observed (while raising the vehicle) is that on the second car, the rear air suspension valves on the left and right sides are "on" (while the front left and right are "off") until the pressure is correct. Then, the display changes, showing the front left and right air suspension valves as "on" (rear off), and the vehicle reaches the desired height.
"With a faulty suspension system, the air spring valve display shows 'on', the compressor runs continuously, and the vehicle does not lift even a centimeter."
Or a troubleshooting guide for air suspension issues using VCDS.
PS car had an accident; the battery was dead for 3 weeks.
I hope I'm in the right department.
Thank you very much icon_biggrin.gif.
Translated on 11-10-2026, 6:31.
Back to top Profile PM Email
Post17-10-2011, 22:24    Subject: Air Suspension Failure: Allroad Problems Quote
Is it possible that something was damaged in the accident?
Did it still work after the accident, or did it only stop working after the battery was dead for 3 weeks?
Translated on 11-10-2026, 6:33.
Driver123
Post18-10-2011, 0:04    Subject: Air Suspension Failure: Allroad Problems Quote
It only started malfunctioning now that I've started using the car. During the repair work, I had to inflate it a few times, and it worked fine then.
The battery was disconnected repeatedly.
It already seems suspicious to me. I've disconnected the battery again. I'll try again tomorrow.
Karma: +590 / -0   Thank you, like it!
Post18-10-2011, 19:50    Subject: Air Suspension Failure: Allroad Problems Quote
Hi!
If the compressor is running, the air has to go somewhere...
You can actually hear a hissing sound.
Otherwise, when you put a car with air suspension on a lift,
"Actually, a bit of caution is advised."
I'm not sure about the Audi, but I'm certain about the Vito.
A switch needs to be activated beforehand.
Otherwise, something might get damaged.
Translated on 11-10-2026, 6:34.
Driver123
TDI-GTI-4-Motion and Ascona likes this.
Post19-10-2011, 8:15    Subject: Air Suspension Failure: Allroad Problems Quote
The compressor didn't have enough power (6 bar).
The car had barely lifted at the rear, and not at all at the front, because it was heavier in the back.
Compressor removed - disassembled - pump and pressure valve thoroughly cleaned - sealed - now working again.
When I connected the compressor, which was already disassembled, to a battery, only a warm puff of air came out of the connection.
Now, it's very difficult to press the opening shut with your finger (now at 8.5 bar).
Basic settings with VCDS, and everything was fine. icon_lol.gif (It wasn't strictly necessary, but I did it anyway).
Translated on 11-10-2026, 6:36.
Post19-10-2011, 8:50    Subject: Air Suspension Failure: Allroad Problems Quote
It was probably just a coincidence that it happened immediately after the accident/when the battery was disconnected.
Translated on 11-10-2026, 6:37.
Post19-10-2011, 9:56    Subject: Air Suspension Failure: Allroad Problems Quote
Ratings - Air Suspension Failure: Allroad Problems
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: Troubleshooting Guide (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts **Hydrostößel: Construction and Function** **Construct... Technical Articles
No new posts Audi Allroad: No Power? Check Turbo Pressure. Diesel Engine Technology
No new posts Allroad AKE V6 2.5TDI: Low Power Below 2500 RPM Diesel Engine Technology
No new posts VAG-Com: Group 000 Not Working - Troubleshooting Diesel Engine Technology
No new posts GRA Retrofit: No Functionality On-Board Diagnostics (OBD)
