Defective Cat => Impact on Turbocharger?
Alchard
Post24-03-2003, 22:47    Subject: Defective Cat => Impact on Turbocharger? Quote
Hello community!
For a few days now, my cat Lysator (3B5 AFN) has been dead. Impact: Initially, there was a faint ringing sound, but then, until yesterday, there was a terrible scraping noise, as if the entire pot was dragging against the bottom, and now there is complete silence... however, the pig is no longer taking sausage from the bread.
I believe my assumption is correct that the catalytic converter has detached (a new one is already on its way), and that it has become clogged with debris and is no longer properly oxidizing... and that it is also preventing the proper passage of exhaust gases, which is preventing the turbo from spooling up, resulting in increased soot emissions, which in turn further clogs the catalytic converter. Is my theory correct? Can my charger also be used now?
Best regards and thank you in advance for your answers...
Alchard
haehnlein
Post24-03-2003, 23:13    Subject: Re: Fault Cat => impact on turbocharger? Quote
Alchard wrote:
Can my charger also be added?
Hi Alchard,
no icon_exclaim.gif Why would the charger break? It's true that a lower volume of air flows through, and therefore he's also turning it over less...and a piece of the exhaust manifold definitely won't go there icon_wink.gif
____________
Kein Auto mehr!
Gremlin
Post25-03-2003, 11:18    Subject: Defective Cat => Impact on Turbocharger? Quote
However, the backpressure in the exhaust area is significantly higher, which, of course, could theoretically cause the AGR valve to be forced open or exhaust gases to enter the compressor housing... of course, this is purely theoretical icon_confused.gif
When dealing with something like this (where the catalyst isn't immediately effective), I always remove the catalyst (or at least partially disable it) and clean it out. If the crumbs are blown into the end of the pot and are also clogging it, you've essentially wasted the catalyst... then it's better to do a little bit of tinkering and run it for 3 days without the catalyst.
See you, Gremlin
diesel.gustav
Post29-03-2003, 22:27    Subject: Defective Cat => Impact on Turbocharger? Quote
Upon request, deleted.
Gremlin
Post30-03-2003, 11:28    Subject: Defective Cat => Impact on Turbocharger? Quote
but of course, the replacement is not immediately apparent...
Cu Gremlin
Uwe
Post30-03-2003, 11:51    Subject: Defective Cat => Impact on Turbocharger? Quote
Gremlin wrote:
What are you doing that causes your cat to break so often???
Best regards, Uwe
Gremlin
Post30-03-2003, 12:05    Subject: Defective Cat => Impact on Turbocharger? Quote
not mine...
Cu Gremlin
Alchard
Post02-04-2003, 12:29    Subject: Now it's been replaced... Quote
Okay, so, now I had a Bosch-cat installed, it was the cheapest one...
I wanted to do it myself, but without a lift... couldn't reach the screws. Now my workshop has replaced it (an independent ...), and they also replaced the timing belt. I must say: flawless work at almost half the VAG price! All used parts, of course, placed in the trunk for inspection.
It's actually the hardness: The ceramic in its original Kat form can actually rotate 180 degrees, so nothing can get through!!!
As far as my experience goes.
alchard
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Failure: Oil Filter Causes Damage Diesel Engine Technology
No new posts Faulty speed controller? On-Board Diagnostics (OBD)
No new posts Faulty exterior temperature sensor on Climatronic? Transmission, Chassis, Body & Interior
No new posts Turbocharger: Types, Benefits & How They Work Diesel Engine Technology
