VW POLO 9N Timing Belt Replacement BBY
chriskross
Post25-10-2011, 15:47    Subject: VW POLO 9N Timing Belt Replacement BBY Quote
Hi!
Can someone tell me when the timing belt needs to be replaced on a 2004 Polo 9n 1.4L with engine code BBY?
Best, Chris.
A6 AFB
A6 BRE DPF
Post25-10-2011, 17:04    Subject: VW POLO 9N Timing Belt Replacement BBY Quote
Replacement: Not required by the manufacturer.
Inspection: First inspection after 90,000 km, then every 30,000 km.
I recommend, for these engines, a service at the latest every 6 years or 90,000 km.
The plastic tensioning rollers or guide rollers tend to break very easily!
chriskross
Post25-10-2011, 19:25    Subject: VW POLO 9N Timing Belt Replacement BBY Quote
Thank you for your information!
I just hit 90,000 km, and I'm going to change the belt!
What does the manufacturer mean by "inspect"? How should one inspect the belt? It might still look quite new, but it could still tear. icon_cry.gif
A6 AFB
A6 BRE DPF
Hornetdream
Registered VCDS User
Post04-01-2012, 20:15    Subject: VW POLO 9N Timing Belt Replacement BBY Quote
Vision and sensory examination... I find it pointless myself.
Even the best mechanic can't see through a belt with the naked eye.
Imagine you're a mechanic and you tell the customer that everything looks fine, and then the belt breaks two weeks later... icon_eek.gif
As TDI-GTI already mentioned... they need to be replaced every 90,000 km.
Octavia_4x4
Post11-01-2012, 9:19    Subject: VW POLO 9N Timing Belt Replacement BBY Quote
For our 1.4 16V engine in the Ibiza (although it was the previous engine code AUA), the recommended intervals were: initial inspection at 90,000 km, then every 30,000 km, and replacement at 180,000 km or 7 years. However, as I mentioned earlier, I also believe that 90,000 km is a reasonable interval for replacement, considering that the 16V engine has 2 camshafts and 16 valves.
Make sure that both belts and both belt tensioners are replaced, meaning a complete kit should be installed.
Unfortunately, I've experienced this twice already: the timing belt (connecting the crankshaft to the camshaft) was replaced, but the smaller connecting belt (connecting camshaft 1 to camshaft 2) and its plastic tensioner, as mentioned before, were not replaced.
The water pump is also driven by the timing belt, so you should replace it at the same time.
Greetings.
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts SDI Polo: Specs, Price, and Review Diesel Engine Technology
No new posts VW Polo 6R: MFA Instrument & VAG-COM Diagnostics On-Board Diagnostics (OBD)
No new posts POLO 9N Servopumpe On-Board Diagnostics (OBD)
No new posts VEHICLE IMMOBILIZER ACTIVE!!! POLO 6N On-Board Diagnostics (OBD)
