AGR Error: 2.0 TDI Issues & Troubleshooting
valeru4 likes this.
Post31-05-2012, 11:21    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
HI.
I recently had a 2.0 CR TDI engine in a Golf+ with an AGR (AdBlue Ready) fault.
The error reappears after approximately 1-2 kilometers of driving.
I don't immediately see a reason for that.
Thursday, May 31, 2012, 11:42:23:31600
VCDS Version: RKS 11.11.3
Data as of: 20120406.
Address 01: Engine, File label: RKS\03L-906-022-CBA.CLB
Control unit part number: 03L 906 022 DB. Hardware: 03L 906 022 G.
Component and/or version: R4 2.0L EDC 0000SG 3799.
Encoding: 0000072
Operating number: WSC 01357 011 00200
VCID: 68D428E25B68FA9
"One error found:"
001027 - Exhaust gas recirculation (EGR) valve (N18)
P0403 - 000 - Malfunction - Warning light ON.
Environmental conditions:
Error status: 11100000
Error priority: 2
Error frequency: 1
Mileage: 74740 km
Time: 0.
Date: 2030.14.14
Time: 10:41:04
Speed: 1495 RPM
Speed: 24.0 km/h
Last: 61.2%
Last: 100.0%
Lambda: 98.6%
Air mass/Hub: 565.0 mg/H
Temperature: 79.2°C
Readiness: 0 0 0 0 1
 Regeldifferenz Abgasrückführung (AGR) CBDB Motor
 File size:  86.01 KB
 Viewed:  25468 times
 Regeldifferenz Abgasrückführung (AGR) CBDB Motor, Detail
 File size:  67.73 KB
 Viewed:  17544 times
Translated on 29-10-2026, 14:44.
Post31-05-2012, 11:25    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
Here is the entire log.
Is it related to the turbo pressure?
He's small - therefore, little fresh air - therefore, complaints about missing the AGR (Agricultural Guarantee Rate) target?
LOG-01-003-011-xxx.xls
 File name:  LOG-01-003-011-xxx.xls
 File size:  602 KB
 Downloaded:  643 times
Translated on 29-10-2026, 14:48.
Post31-05-2012, 12:00    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
Hello Martin,
The software part number from the engine control unit is relevant for identifying the engine code letter. This number is 03L-906-022-DB (software version 3799), and based on this, the engine code letter should be CBDB.
In the 4-digit VAG engine identification codes, the first three letters, such as CBD, represent the engine block (hardware), while the fourth letter indicates the specific variant (e.g., different engine power, emission standards, etc.).
The error likely occurred due to discrepancies between the desired and actual air mass values of the EGR system. At this mileage, mechanical failures in the EGR system are the most common cause.
See also:
Okay, I'm ready. Please provide the German text you want me to translate into English.
Is it due to the turbo pressure?
It's possible, but the AGR valve could also be the cause. However, if the normal boost pressure is achieved intermittently, then the turbocharger and intercooler system are likely working correctly.
Translated on 29-10-2026, 14:49.
Post31-05-2012, 12:40    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
It appears to be the same issue as with Rainer. Up to 2585, the actual value matches the target value. However, after 2585, the valve remains closed (= high air mass), while the target value expects an air mass below 300 mg/H.
Translated on 29-10-2026, 14:51.
The error likely occurred due to discrepancies between the desired and actual values of the air mass measured by the EGR system. The most common failures at this mileage are mechanical defects in the EGR system.
If it's the same as with the A4, you should be able to hear a noticeable sound from the AGR valve after starting the engine.
The design is already outrageous. As far as I know, the manufacturer is Pierburg.
Translated on 29-10-2026, 14:52.
Post31-05-2012, 12:43    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
Since I don't have a comparison valve here at the moment, I can't tell whether it's "regulating" or "chattering."
I need to test this on my BMR/BLS exam to understand how to categorize it.
AAAAAAA IDEA.
I'm making a video of this N18 and of mine - hopefully, you can already "make something out" of it.
Translated on 29-10-2026, 14:53.
Post31-05-2012, 14:53    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
At the time, I didn't notice any unusual noises.
Translated on 29-10-2026, 14:54.
Post31-05-2012, 15:59    Subject: AGR Error: 2.0 TDI Issues & Troubleshooting Quote
At the time, I didn't notice any unusual noises coming from my car.
You could hear the gears grinding, which was quite noticeable. If I remember correctly, it happened shortly after starting the engine, until the EGR system stopped working. It doesn't always have to be like that. But if it's making unusual grinding and clanking noises...
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
