Polo 9N3: Oil Leak in Transmission
Go to page: 1, 2  Next
stolley
Karma: +38 / -1   Thank you, like it!
Post17-03-2017, 15:35    Subject: Polo 9N3: Oil Leak in Transmission Quote
Hello everyone!
My Polo (9N3, 1.4L TDI 3-cylinder, BWB, mileage: 362,000 km) is leaking transmission oil. I have already cleaned the underside of the transmission with brake cleaner and inspected it. According to my inspection, both the oil filler opening and the drain plug are tight.
The transmission oil is leaking from the top. The top of the transmission is also quite oily. Next, I'm going to apply some degreaser thoroughly and carefully steam clean the transmission.
Before I go any further, here's my question:
Is this a typical phenomenon? Do you have any idea where the leak might be – where exactly should I look?
By the way, the transmission has the identification code "JDE" and is a 5-speed manual transmission.
Thank you all!
Translated on 03-09-2026, 19:22.
Karma: +645 / -0   Thank you, like it!
Post17-03-2017, 18:27    Subject: Polo 9N3: Oil Leak in Transmission Quote
You don't need a steam cleaner; brake cleaner and compressed air are simpler, just be careful not to pollute the environment.
Translated on 03-09-2026, 19:23.
stolley
Post17-03-2017, 18:35    Subject: Polo 9N3: Oil Leak in Transmission Quote
Rüdi wrote:
You don't need a steam cleaner; brake cleaner and compressed air are simpler, just use them carefully so you don't pollute the environment.
Who has compressed air at home these days?
Post18-03-2017, 7:55    Subject: Polo 9N3: Oil Leak in Transmission Quote
Compressed air is more readily available than a steam cleaner; you can also borrow a compressor or know someone who has one.
There aren't many obvious places where there could be a leak, so it's likely the issue is with the wave generator.
Is the transmission possibly overfilled?
Translated on 03-09-2026, 19:24.
stolley
Post18-03-2017, 17:24    Subject: Polo 9N3: Oil Leak in Transmission Quote
Rüdi wrote:
Compressed air is more readily available than a steam jet, and you can also borrow a compressor or know someone who has one.
Funny, I don't know anyone who owns an air compressor. But almost everyone has a steam cleaner... anyway, I was just at a self-service car wash.
My finding: The transmission oil is leaking from the upper left-hand threaded fitting between the engine and the transmission (a coolant hose is attached to the double fitting).
Do you have any ideas about what I could do? Please don't tell me that the transmission needs to be removed to replace the seal!
There was actually a little too much oil in it (maybe 10ml).
Translated on 03-09-2026, 19:26.
Post19-03-2017, 7:31    Subject: Polo 9N3: Oil Leak in Transmission Quote
Take a picture of the spot.
Translated on 03-09-2026, 19:27.
stolley
Post19-03-2017, 11:53    Subject: Polo 9N3: Oil Leak in Transmission Quote
Sure!
I've now decided to unscrew the screw in question, apply sealant to the head, and then screw it back in.
Can I do that? Or is there a risk of something shifting or becoming misaligned between the engine and the transmission?
 File size:  1.2 MB
 Viewed:  2283 times
Post19-03-2017, 12:50    Subject: Polo 9N3: Oil Leak in Transmission Quote
A little more distance would be helpful; you can barely see anything except the screw.
Translated on 03-09-2026, 19:28.
Post19-03-2017, 12:57    Subject: Polo 9N3: Oil Leak in Transmission Quote
What appears to be oil there is almost certainly not transmission fluid.
Transmission oil is always relatively light in color.
Post19-03-2017, 15:21    Subject: Polo 9N3: Oil Leak in Transmission Quote
@ Stolley - Could you please highlight what you mean?
The picture shows something more like a sludge of motor oil.
stolley
Post19-03-2017, 16:50    Subject: Polo 9N3: Oil Leak in Transmission Quote
Thank you for your "concern" (or "sympathy").
I'll try to post a more informative photo once I've driven a few kilometers!
Translated on 03-09-2026, 19:29.
stolley
Post20-03-2017, 13:39    Subject: Polo 9N3: Oil Leak in Transmission Quote
Okay, here are some photos. It's not easy to photograph. There's definitely a lot of oil coming from above, which accumulates in the area around the transmission identification plate. However, it also runs down on the other side of the "bell housing," towards the rear.
 File size:  1.79 MB
 Viewed:  780 times
 File size:  1.92 MB
 Viewed:  749 times
 File size:  1.77 MB
 Viewed:  1226 times
Translated on 03-09-2026, 19:30.
Post20-03-2017, 16:27    Subject: Polo 9N3: Oil Leak in Transmission Quote
... Actually, there was slightly too much oil in it (maybe 10ml).
In my opinion, by doing that, you are indirectly admitting that you have topped up or changed the transmission oil. icon_thanks.gif
Assuming the correct amount of transmission fluid is in the transmission, using the wrong type of transmission fluid can cause it to "foam" and bubble out while driving.
Translated on 03-09-2026, 19:31.
stolley
Post20-03-2017, 17:59    Subject: Polo 9N3: Oil Leak in Transmission Quote
Best regards, Rainer
Hello Rainer,
"Yes, you are generally correct: about half a year ago, I added a little over a liter of oil. The reason was that the transmission sounded strange when driving in low gear. At the same time, I noticed that everything around the transmission was covered in a sticky substance - for me, this was an indication that transmission oil had been leaking out in very small amounts for a long time and had hardened."
The car was parked on a slightly sloping driveway while being filled, which likely explains the minor overfilling.
The oil level should be correct now (at the bottom edge of the fill opening). However, it's still leaking...
What kind of component is installed between the transmission and the engine?
Volker
Translated on 03-09-2026, 19:33.
Post20-03-2017, 18:23    Subject: Polo 9N3: Oil Leak in Transmission Quote
stolley wrote:
What kind of seal is actually installed between the transmission and the engine?
None at all, because there's nothing there that needs to be sealed. icon_wink.gif
And are you 100% sure it's transmission fluid? To me, it looks more like a leak from the tandem pump.
Translated on 03-09-2026, 19:34.
Post20-03-2017, 19:06    Subject: Polo 9N3: Oil Leak in Transmission Quote
I also assume it's a tandem pump. The motor seals against the crankshaft at the front. If the seal fails, the oil will leak out from the bottom. If it leaks out from the top, the clutch will be disengaged.
Translated on 03-09-2026, 19:35.
No new posts Doku Polo MJ 2002, Gearbox noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Automatic transmission error. Gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Doku: Dimming Display Issue (1998-2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 6n2 TDI: Gearbox, Transmission, Replacement Diesel Engine Technology
No new posts Polo 6N1 Gearbox DKE Transmission, Chassis, Body & Interior
No new posts Polo diesel with a gasoline transmission??? Diesel Engine Technology
No new posts R Gear Problem: Polo AKU Transmission Compatibility Diesel Engine Technology
