Engine Starting: No Gas Intake - Special Issue
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
findus170
Post24-11-2011, 22:48    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Hello fellow diesel mechanics,
I also encountered an electrical problem during the installation of the auxiliary heater.
You're already moving the cables under the dashboard and in the area where the water tank cables pass through.
The error memory is empty, and the problem only occurs once after starting the engine. After that, everything is normal until the next start.
As the diagram shows, the car reduces the fuel injection amount once a certain speed is reached. This happens in both first and second gear, as soon as the speed is exceeded when accelerating. After releasing the accelerator pedal, it then continues as normal.
Where should I look? I would really appreciate any tips.
Best regards and thank you!
Findus.
Vehicle type: 1J - VW Golf/Bora IV.
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Vehicle Identification Number: WVWZZXXXXXXXXXXXX
Mileage: XXXXXX km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Label file: RKS\038-906-019-AXR.lbl
Part number: 038 906 019 DD
Component: 1.9L R4 EDC 0000SG 1518
Encoding: 00002
Operating number: WSC 01266
VCID: 5CB3E6D2E6BB
WVWZZZXXXXXXXX VWZ7Z0B5XXXXXX
No errors found.
Readiness: 0 0 X X X
Address 03: Brakes Label file: RKS\1C0-907-37x-ABS.lbl
Part number: 1C0 907 379 L
Part: ABS FRONT MK60 0101
Encoding: 0001025
Operating number: WSC 01266 785 00200
VCID: 33616D6E2BA5
No errors found.
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 A
Part: 27 AIRBAG VW51 01 0004
Encoding: 12855
VCID: 224F982A845F
No errors found.
Address 17: Combination Instrument
Label file: RKS\1J0-920-xx5-17.lbl
Part number: 1J5 920 806 G
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V11
Encoding: 01112
Operating number: WSC 00000
VCID: 306B6262DAB3
WVWZZZ1JZ3W040134 VWZ7Z0B5135867
No errors found.
Address 19: CAN-Gateway
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: F0EB22629A33
No errors found.
Address 46: Comfort System
Label file: RKS\1C0-959-799.lbl
Part number: 1C0 959 799.
Component: 1F Comfort Device HLO 0001
Encoding: 00259
VCID: F4E32E72EE2B
Part number: 1C1959801A
Component: 1F TÔrsteuer.FS KLO 0004
Part number: 1C1959802A
Component: 1F Throttle Control.BF KLO 0004
Part number: 1C0959811A
Component: 1F Throttle control.HL KLO 0004
Part number: 1C0959812A
Component: 1F Throttle Control.HR KLO 0004
No errors found.
Address 56: Radio
Label file: RKS\1J0-035-15x-56.lbl
Part number: 1J0 035 152 F
Component: Radio BNO 0006
Encoding: 00001
VCID: 214D97268159
No errors found.
End.
 File size:  104.36 KB
 Viewed:  3692 times
VW ID 7 GTX
Translated on 06-09-2026, 6:28.
Post24-11-2011, 22:57    Subject: Engine Starting: No Gas Intake - Special Issue Quote
It would be interesting to see the air mass, target boost pressure, and actual boost pressure values.
Translated on 06-09-2026, 6:36.
findus170
Post25-11-2011, 10:47    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Sure!
Findus.
 File size:  93.96 KB
 Viewed:  3177 times
LOG-01-003-011-xxx.csv
 File name:  LOG-01-003-011-xxx.csv
 File size:  2.23 KB
 Downloaded:  473 times
VW ID 7 GTX
Post25-11-2011, 14:41    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Saying "hey, I have a problem" and then pointing out where everything is fine doesn't really make sense, does it?
Translated on 06-09-2026, 6:37.
findus170
Post25-11-2011, 19:45    Subject: Engine Starting: No Gas Intake - Special Issue Quote
So, I hope it's now clear what's going on.
Greetings and thank you!
Findus.
 File size:  134.66 KB
 Viewed:  3117 times
 File size:  117.99 KB
 Viewed:  3111 times
LOG-01-003-011-xxxzwoter.csv
 File name:  LOG-01-003-011-xxxzwoter.csv
 File size:  1.97 KB
 Downloaded:  511 times
LOG-01-003-011-xxx-starterster.csv
 File name:  LOG-01-003-011-xxx-starterster.csv
 File size:  1.54 KB
 Downloaded:  484 times
VW ID 7 GTX
mserge
Post28-11-2011, 12:21    Subject: Engine Starting: No Gas Intake - Special Issue Quote
What are your brake lights telling you? Is it possible that the brake switch is stuck or broken?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 06-09-2026, 6:38.
findus170
Post28-11-2011, 20:34    Subject: Engine Starting: No Gas Intake - Special Issue Quote
I'll check that out, but not until the weekend.
Thanks for the tip, I heard they tend to break easily.
best regards
Findus.
VW ID 7 GTX
mserge
Post29-11-2011, 10:26    Subject: Engine Starting: No Gas Intake - Special Issue Quote
After the initial hiccup, does it then function normally?
If you let it run in neutral for about 30 seconds, will it then work normally again, or not?
Post29-11-2011, 10:35    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Hi.
Here's another tip regarding the diagrams:
I find spline interpolations a bit excessive for such coarse data points.
They are creating a false impression of a smooth, gentle measurement curve that doesn't actually exist.
Strictly speaking, linear connections aren't necessarily better either, but the jagged edges tend to indicate to the viewer that things are a bit more rough around the edges here.
Translated on 06-09-2026, 6:39.
Post29-11-2011, 14:08    Subject: Engine Starting: No Gas Intake - Special Issue Quote
How can the acceleration be related to the RPM "as usual" (= nothing or something?) when there is absolutely nothing discernible in this log?
Check the brake pedal sensor, etc. (see also the corresponding bits in the measurement block within the engine control unit, see the label file), or the boost pressure may be too low (is there a leak in the charge air system?). The relatively low air mass also doesn't quite fit with this.
Translated on 06-09-2026, 6:40.
comco
Karma: +1 / -3   Thank you, like it!
Registered VCDS User
Post29-11-2011, 20:14    Subject: Engine Starting: No Gas Intake - Special Issue Quote
How did you connect the fuel line for the auxiliary heater?
As intended, either by taking a separate sample from the fuel tank or from the fuel line in the engine compartment?
Bye.
JĂŒrgen.
Bye
JĂŒrgen
_________________________________________
FĂŒr den Spass/Winterauto: Audi TT Q und die Arbeitstier: Octavia 2 RS,
FĂŒr noch mehr Spass: R1200S, Laverda Formula, SV 1000 und NSU MAX
Translated on 06-09-2026, 6:41.
findus170
Post29-11-2011, 22:42    Subject: Engine Starting: No Gas Intake - Special Issue Quote
I will check that tomorrow; otherwise, I always end up leaving normally after a short time after the start.
Check the brake pedal sensor, etc. (see also the bits in the corresponding measurement block in the engine control unit, see label file), or the boost pressure may be too low (is there a leak in the charge air system?). The relatively low air mass also doesn't quite fit with this.
Best regards, Rainer
Okay, let me clarify: When I'm in first gear, I engage the clutch, then hold a certain position on the accelerator and accelerate, I reach the point where the automatic throttle cut-off kicks in.
The acceleration remains reduced, regardless of how long I stay in that position or even if I press the accelerator further. Only after releasing the accelerator pedal completely to 0 and then pressing it again can you accelerate normally.
In second gear, the situation is different. I didn't need to ease off the accelerator; instead, he accelerated after the "dip" as would be expected for second gear and the gas pedal position. Unfortunately, the road ended there, and I didn't want to turn around again.
I will test the brake pedal switch this weekend.
The actual mass airflow value is already significantly lower than the target value. Are there any standard diagrams available that show what it should look like when there is no fault?
As intended, with the extra fuel filler.
Thank you in advance for the suggestions!
Findus.
VW ID 7 GTX
Translated on 06-09-2026, 6:44.
findus170
Post02-12-2011, 22:12    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Okay, I've dedicated some more time to this.
The brake light switch or the cable connection to the engine control unit seems to be a likely culprit. It has four terminals, two for the brake lights and two for the engine control. The brake actuation signal reaches the brake control unit, but not the engine control unit.
Now I've tried something where you can brake and accelerate at the same time.
Last winter, I was wearing very wide rubber boots, and I accidentally pressed both the gas and brake pedals at the same time. Back then, the gas pedal would automatically return to zero if you pressed the brake pedal while the gas pedal was already being pressed.
Okay, so there's a new brake light switch first, which doesn't cost much. After that, I'll see what else needs to be done.
Thank you very much and have a nice weekend!
Findus.
VW ID 7 GTX
Translated on 06-09-2026, 6:47.
findus170
Post13-01-2012, 15:07    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Problem solved!
After replacing the brake light switch, the problem persisted. Then I checked the connector assembly in the water tank, and I found that a connector had come loose during the installation of the heating cables. This connector was for the circuit between the brake light switch and the EDC (Electronic Stability Control). I reconnected it, and everything is working fine again!
Thank you for the search tips!
Findus.
VW ID 7 GTX
Translated on 06-09-2026, 6:48.
Post13-01-2012, 16:03    Subject: Engine Starting: No Gas Intake - Special Issue Quote
Thank you for your feedback.
Translated on 06-09-2026, 6:49.
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G4 1.6 FSI knocking shortly after start? Gasoline Engine Technology
No new posts AFN only accepts gas up to 1500 RPM after starting Diesel Engine Technology
No new posts TDI No Power After Start - Troubleshooting Diesel Engine Technology
No new posts Engine Spin-Up After Start Diesel Engine Technology
