happy Guest
30-08-2004, 20:58 Subject: turbocharger oil leak and whistling at 1800 RPM |
I have a Golf IV 1.9 TDI with 150 horsepower. During the oil change, it was noticed that there was a slight oil leak coming from the turbocharger. The average oil consumption is approximately 1 liter per 15,000 kilometers.
In addition, there is a hissing sound at 1,800 RPM, which is not excessively loud, but can be heard clearly when the window is open.
Can someone give me a tip?
Thank you in advance.
Joined: 04/12/2002 Posts: 18099 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
30-08-2004, 21:21 Subject: turbocharger oil leak and whistling at 1800 RPM |
Either the intercooler pipe or hose is cracked, or the connections of the pipes are leaking. O-rings in the connectors (haven't disassembled any yet)?
Profile PM WWW Garage |
happy Guest
30-08-2004, 21:26 Subject: turbocharger oil leak and whistling at 1800 RPM |
Thank you.
As far as I know, no one else has tried that before.
