Relay Clicking After Start / Cold Start Problem
joeol77
Post06-04-2003, 19:26    Subject: Relay Clicking After Start / Cold Start Problem Quote
'I'm having starting problems with my Audi A3 TDI 110hp, manufactured in 1999, when it has been standing for several hours (e.g., overnight or during the day).'
Once it's turned on, it starts up and runs without any problems.
I've noticed that, seemingly, a relay or something else often malfunctions repeatedly after the initial startup phase.
Could the problem be with the parking meter?
Or what else could it be?
Could you please tell me where I can find the fuel cutoff switch in the engine compartment?
Thank you very much, and best regards.
joeol77
Translated on 22-10-2026, 14:09.
Karma: +807 / -0   Thank you, like it!
Post07-04-2003, 9:51    Subject: Relay Clicking After Start / Cold Start Problem Quote
The fuel shut-off valve is located in the ESP (Electronic Stability Program) and blocks the fuel supply. If the shut-off valve were to activate, the engine would either stall immediately or experience excessive misfiring.
Translated on 22-10-2026, 14:10.
renwal
Post07-04-2003, 22:32    Subject: Relay Clicking After Start / Cold Start Problem Quote
If you hear a clicking sound around 2500 RPM, it's likely the glow plug relay. It shouldn't be audible below or above that RPM range.
renwal
P.S. Of course, this only applies under appropriate outdoor temperatures.
Translated on 22-10-2026, 14:11.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Relay 109/219" for the Passat 3C BLS Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Diesel Engine Technology
No new posts 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Diesel Engine Technology
No new posts Airbag Warning: Seat Adjustment Issues Transmission, Chassis, Body & Interior
