Audi A4 electrical problem
gullianderle
Post21-03-2012, 7:36    Subject: Audi A4 electrical problem Quote
Okay, I'm also having a problem with an Audi A4, manufactured in August 2001, with the AWX engine. In this car, the turn signals, high beams, and power windows are no longer working. It's very suspicious that when you turn off the ignition, the radio should normally turn off. However, in this case, it remains on (possibly a faulty ignition switch?). The error indicates a communication failure with the steering column electronics.
I now need to find the wiring diagram and check the circuit for the window lifters and the light switch.
Post21-03-2012, 8:36    Subject: Audi A4 electrical problem Quote
Is the steering column electronics still accessible via diagnostics?
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Electrical Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Mass Errors & Electrical Issues: Common Problems Transmission, Chassis, Body & Interior
No new posts Wiper Motor Problem: Electric, Wiring, Front Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
