PD Element Design: Creative Typography Solutions
hame22
Post31-05-2008, 9:24    Subject: PD Element Design: Creative Typography Solutions Quote
Hello everyone,
Is there a way to replace the seals on the PD elements?
To be reviewed without being expanded?
Is the LLRR (Leakage Location and Rate Ratio) a sufficient indicator for leaky PD (Partial Discharge) elements?
Translated on 18-09-2026, 9:03.
Post31-05-2008, 10:00    Subject: PD Element Design: Creative Typography Solutions Quote
No, the only solution is to take it apart.
Translated on 18-09-2026, 9:04.
hame22
Post01-06-2008, 9:54    Subject: PD Element Design: Creative Typography Solutions Quote
Hello Rainer,
Do you happen to have the part number for that set?
or the price?
wingmaster
Avatar-wingmaster
Post01-06-2008, 10:27    Subject: PD Element Design: Creative Typography Solutions Quote
"038189051C costs €20.29 and is always only for one PD unit."
charlyfirpo
2013 Volkswagen Golf
dieselschrauber likes this.
Post05-06-2008, 19:05    Subject: PD Element Design: Creative Typography Solutions Quote
Hello.
There is a way to check the O-rings, specifically when inspecting the tandem pump.
Coolant temperature: minimum 85 °C.
Connect the pressure gauge to the test port of the tandem pump.
- Increase the speed to 4000 RPM.
- Observe the pressure displayed on the pressure gauge.
Set point: minimum 7.5 bar.
If the target value is not reached:
- Clamp the return line between the fuel filter and the tandem pump using a hose clamp or pliers.
Is the target value being reached now?
Pressure loss in the pump-nozzle injectors.
- Replace the O-rings of the pump-injector units.
- Replace the tandem pump.
A leak can be detected internally in this way.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 18-09-2026, 9:06.
hame22
Post06-06-2008, 19:01    Subject: PD Element Design: Creative Typography Solutions Quote
Thank you for the response.
How reliable is this test?
Have you ever done this before?
Translated on 18-09-2026, 9:07.
charlyfirpo
Post07-06-2008, 7:35    Subject: PD Element Design: Creative Typography Solutions Quote
Hello.
I've done this before. However, in my case, it was to test my insulin pump.
For reliability: Source VAG.
Translated on 18-09-2026, 9:08.
Biggi
Registered VCDS User
Post16-04-2012, 20:42    Subject: PD Element Design: Creative Typography Solutions Quote
Hello, where can I get a pressure gauge like that, and what kind of connection does it have?
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post17-04-2012, 2:14    Subject: PD Element Design: Creative Typography Solutions Quote
For the VW Transporter T5 AXE (R5 TDI), it's a M12x1.5 connection. It might be the same for you, but I can't guarantee it!
I built the fitting myself: I connected it with a threaded fitting, a Festo hose, and a standard pressure gauge up to about 15 bar.
Translated on 18-09-2026, 9:09.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Rear brake caliper bolt Transmission, Chassis, Body & Interior
No new posts PD Elements: Differences Explained Diesel Engine Technology
No new posts PD Elements: BKD Car Seats Diesel Engine Technology
No new posts Fuel injectors & PD elements Diesel Engine Technology
