Golf 4 engine control unit programming
Cr4sh
Registered VCDS User
Post14-04-2012, 14:26    Subject: Golf 4 engine control unit programming Quote
We installed an AUQ engine in a Golf 4, but now we're having trouble connecting the engine control unit to the WFS3.
The login codes for both control units are present and functional. The problem lies in the fact that when accessing the MSG (Main System Gateway) and navigating to "Adjustment" -> "Channel 50", you need to enter the login code from the WFS3. If you do that and click "Test," you'll get the following message:
"System n.i.O."
I suspect the problem is that the current MSG (Message) contains a Seat chassis number, or that it's being displayed incorrectly in the Extra system. The part number for the MSG is 06A 906 032 HN, which suggests it's a control unit for a VW engine?
According to Google, the message "System n.i.O." indicates a problem with connecting a Seat control unit to a VW vehicle.
What can I do now?
Post14-04-2012, 15:07    Subject: Golf 4 engine control unit programming Quote
Is it equipped with an IMMO III AI system?
Cr4sh
Post14-04-2012, 15:20    Subject: Golf 4 engine control unit programming Quote
Yes, an IMMO3 control unit is installed in the speedometer.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit (ECU) Calibration for WFS On-Board Diagnostics (OBD)
No new posts Polo 9N FSI engine control unit programming Gasoline Engine Technology
No new posts Immobilizer: Engine Control Unit (ECU) Not Learning On-Board Diagnostics (OBD)
No new posts Golf 5 Key Programming: How-To Guide On-Board Diagnostics (OBD)
