charmillo
2005 Audi A6 Avant Premium Support
12-04-2012, 11:33 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Hello everyone,
I'm relatively new here, and I'm having a problem with a friend's car. His Audi A4 Avant with a 1.9 TDI engine isn't pulling at all. The maximum RPM is just over 3000, and it drives like a tractor...
"After that, the car was connected to VCDS, and the following error was found..."
Address 01: Engine Label file: RKS\038-906-018-AFN.lbl
Control unit part number: 038 906 018 R.
Component and/or version: 1.9L R4 EDC 00SG 1632.
Encoding: 00002
Company number: WSC 06325
VCID: 254598D8BFFA27B
"One error found:"
00522 - Coolant temperature sensor (G62)
30-10 - Interruption / Short circuit after positive voltage - Occasional.
Readiness: Not available
Furthermore, I took it for a test drive and logged some data... it seems the turbocharger is definitely faulty, as it's no longer building boost. I logged data from measurement points 3, 8, and 11.
Hmmm, I don't have much faith in workshops here, since I live in France, and they don't really put in much effort...apparently, some are overwhelmed by the engine or want to just install a complete new engine...of course, all without any diagnosis or a proper test drive!
I would be very grateful if you could take a look at the file and give me some feedback.
Edit Admin: Data clutter revised.
Thank you very much.
Flo.
| Description: |
| Log und Auswertung Leistungsverlust, AFN Motor im Audi A4 |
 Download |
| File name: |
Leistungsverlust-AFN-Audi-A4.xls |
| File size: |
12 KB |
| Downloaded: |
578 times |
Translated on 14-10-2026, 5:58.
Profile PM Garage |
anywhere Blaumann
12-04-2012, 12:27 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
I had a similar problem with my ALH engine; it wouldn't go above 110 km/h. There were no error codes stored either.
The  also noticed a faulty turbo and wanted to install a new one for me.
The workshop in my village then agreed to open the hood, and it turned out that a broken vacuum hose was causing all the problems.
Perhaps you could take a look at it sometime; I seem to recall it was "on the way" to the engine control unit.
Marco.
Translated on 14-10-2026, 6:02.
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
12-04-2012, 12:39 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Okay, please check if the VTG adjustment mechanism is actually moving and if there is vacuum pressure at the connection of the VTG vacuum actuator. There should be vacuum pressure even when idling. This can be easily checked/felt by disconnecting the hose.
When the vacuum hose is connected, the VTG linkage should be adjusted approximately 10mm.
If you hear hissing or whistling noises when accelerating (i.e., as soon as boost pressure builds up), it could indicate a leak (e.g., a crack in a hose) in the hose connections between the turbocharger, intercooler, and intake manifold.
Definitely replace the defective sensor.
Post the result. Then we can proceed. If there is no vacuum, please first check the hoses for any damage.
And please post the log files in the same format as they are saved by the program.
3B5 AJM
Translated on 14-10-2026, 6:03.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
12-04-2012, 12:44 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
I took the liberty of extracting a (small) useful section from your log and revising the graphic.
Please translate the following text from German to English. Provide ONLY the translation, no explanations.
https://community.dieselschrauber.org/en/viewtopic.php?t=12979
When creating logs, please note that converting to .XLS format is unnecessary when using KDataScope.
Your log indicates insufficient air mass, despite attempts to build up boost pressure.
Therefore, the amount of fuel injected is limited, and the car won't move forward.
Please check the following:
- Is the mass airflow sensor correct and okay? Does the VTG adjustment work perfectly? As a test, replace the mass airflow sensor with an identical one (VAG part number is the same, including the letters at the end!).
- Does the catalytic converter rattle when tapped? The catalytic converter can become loose within its housing and tilt, resulting in a nearly blocked exhaust pipe and a corresponding low air mass flow.
- Is the hose to the pressure sensor of the turbocharger okay? Without pressure, the boost pressure is limited to 0.6 bar... See the vacuum hose diagram for TDI: https://community.dieselschrauber.org/en/viewtopic.php?t=3101
Translated on 14-10-2026, 6:06.
Profile PM WWW Garage |
BM Profi-Schrauber
12-04-2012, 12:51 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Oops, I completely forgot about the cat.  Now he has something to do.
3B5 AJM
Translated on 14-10-2026, 6:07.
mullemaus Guest
12-04-2012, 22:53 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
I would suspect a wastegate in that A4. The part number for the control unit is not from the AFN  .
Translated on 14-10-2026, 6:08.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
12-04-2012, 23:02 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
According to the original poster, it's supposed to be an ALH (presumably a type of vehicle), and they seem to think it belongs to someone who owns a VTG (likely another type of vehicle or company).
Profile PM Garage |
mullemaus Guest
12-04-2012, 23:14 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
ALH would be a Golf/Bora engine, not a longitudinally mounted engine like is common in the A4  . I would initially consider that to be incorrect  .
12-04-2012, 23:29 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Okay, you've convinced me. A 90 horsepower diesel engine in an A4 B5 will be either a 1Z or an AHU  .
Translated on 14-10-2026, 6:09.
Profile PM Garage |
12-04-2012, 23:34 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
klahaui wrote: | Well convinced, a 90hp diesel in an A4 B5 will be a 1Z engine in 99% of cases.  | For vehicles manufactured in 1996, it's 100% a 1Z. If it were newer, the AHH could still be a possibility, but not in this case.
Profile PM Garage |
mullemaus Guest
12-04-2012, 23:35 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Yes and no. I think in 1996 it will be an A4 - B5, and therefore a longitudinally mounted engine = AHU. 1Z was the counterpart for the transversely mounted engine.
'Would that be the part number? As I recall, the ones with the '1Z' designation used to have the '028' part number.'
Translated on 14-10-2026, 6:10.
12-04-2012, 23:37 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
I've already revised mine  .
As mentioned, it could also be the AHU.
Because both "Wastegate" and "Mulle" are correct, as Mulle already mentioned.
Translated on 14-10-2026, 6:11.
Profile PM Garage |
12-04-2012, 23:44 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
038906018R is the control unit for the AHU, at least according to Tante AKTE  .
However, the 1Z was definitely also available in the B5 model, as I personally owned one.
EDIT: The AHH product became available starting in 1998.
Profile PM Garage |
mullemaus Guest
12-04-2012, 23:54 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Translated on 14-10-2026, 6:12.
Herbert Profi-Schrauber
13-04-2012, 8:03 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
The 1Z engine was also installed longitudinally in the Audi. When the engine number sequence ran out, it was replaced by an AHU. For vehicles manufactured in 1996, both the AHU and AFN engines are possibilities. However, perhaps Charmillo can confirm which engine he has.
Translated on 14-10-2026, 6:13.
charmillo
13-04-2012, 8:24 Subject: A4 Avant 1.9 TDI: Power Loss Troubleshooting |
Hello everyone,
First of all, thank you for your Hilde. I made a mistake; the A4 has an AHU engine... (ALH was my old Ibiza...  ).
"This weekend, I'll check the VTG (throttle valve control) and possibly also the MAF sensor (mass airflow sensor). Unfortunately, I don't have a suitable MAF sensor to use for testing... Hmm, I'll try doing a diode test instead..."
/viewtopic.php?t=3347&highlight=Diode
Translated on 14-10-2026, 6:14.
Profile PM Garage |
